-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   82 928 us No start (http://forums.pelicanparts.com/porsche-928-technical-forum/486584-82-928-us-no-start.html)
vdubr928 07-23-2009 07:03 PM
What should I use to clean the lines? Also who makes an inexpensive kit to do the injector lines? Mine are in ok shape so I was going to wait till I pull the motor again to do the rear seal and reaplace all the injectors.
Danglerb 07-23-2009 07:10 PM
Roger has a kit, but its fuel injection grade hose and clamps. The old stuff comes off and the fittings, collar things, are not reused. ************
DMRK 07-23-2009 08:29 PM
You can clean the lines with carb/FI cleaner and blow them out with compressed air.
The hose may look good but it is 27 years old. Also the stuff made today is prob better.
http://forums.pelicanparts.com/uploa...1248405983.jpg
This is a close up of what it looked like after pulling it off the fuel rail (just broke off)
http://forums.pelicanparts.com/uploa...1248406119.jpg
Mrmerlin 07-23-2009 08:33 PM
I would send out the injectors to Witchunter, they will be cleaned and flow tested about 120.00
vdubr928 07-23-2009 09:38 PM
Wow... All of them? That's a ton cheaper then buying new injectors.
vdubr928 07-30-2009 03:22 PM
It was the fuel pump guys. Thanks for all the info. I ordered the fuel line kit from roger and I'll be sending the injectors off to get cleaned when I install that.
vdubr928 08-02-2009 04:05 PM
Ok, Had the car towed home again yesterday. Starting to get frustrated. Pretty handy with an electrical diagram and a test meter but need some direction. Seems again like the injectors are pulsing and the plugs are firing but the car just stumbles. Won't start. Maybe injector timing is off? Any help would be really appriciated.
jared0271 08-02-2009 05:02 PM
I have been watching this thread because I am having the same problem with my 84 928s. I was about to order a fuel pump until reading your last post. I drove my car to norfolk and back (about 1300 miles round trip) with no problems,the next morning same as yours stumbles but will not start. I am going to get a fuel pressure tester and start there I guess, any idea if the standard tester works on theese cars?
Danglerb 08-02-2009 09:14 PM
All the injectors fire once or twice per revolution at the same time.
I always think Green wire without other suspects.
vdubr928 08-03-2009 02:02 AM
Ok, Didn't know that. I hear them clicking.... What does that mean? No fuel pressure? Just installed a pump. Worked for 20 miles? Still running. All things are the same as before. Car stutters but won't start.
i guess waht I'm asking (not telling please don't get me wrong) is that the green wire... (like most 80's german cars 70's too) feeds the coil ultimatly. If the green wire was bad would I still get a spark on every revolution? i just hate to spend another hundred bucks and still have to tow it home!
vdubr928 08-05-2009 05:04 PM
Traced to Time Temp Sensor.
Thanks to all who helped me along. :)
