Flex Fan Revisited
Well, here is the finished product. I gave the machinist the stock Clutch fan shaft & he made a new mounting flange for a flex fan. The fan will mount on the radiator side of the mounting flange & will be in the same position as the stock fan was, just inside the shroud. He also drilled & tapped the center of the shaft to use a bolt & flat washer as a safety precaution to hold the fan & flange, although I don't think it's necessary. I have no connection with the machine shop, just passing on the info. Attached are two photos of the finished product & a photo of this business card.
Old 08-12-2009, 04:59 PM
