removing wiring for hood?
how does one disconnect the wiring from the hood, to completely remove a hood?
Old 08-06-2009, 07:03 PM
Heavy Metal Relocator
rhjames's Avatar
there is a male/female plug (for the underhood light) where the washer hose goes up into the hood.
--Russ
Absence of Evidence, is not Evidence of Absence.
Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma."
Old 08-06-2009, 07:05 PM
Petie3rd
Mrmerlin's Avatar
the hood wire connector is under the black cowl cover, remove the cover then follow the wires it is usually connected near the center of the cowl area IIRC its a 3 wire connector, you may also have another connector thats for the heated nozzles this connector is also about in the same spot.
Use a lighter to heat the washer hose at the junction block then pull it off
Old 08-06-2009, 08:00 PM
