what is this in intake, crudy like line of fluid
is it ok? it has always been clean and dry any other times ive seen in there
http://forums.pelicanparts.com/uploa...1250182490.jpg |
oil deposit
928 engines ingest a lot of oil...... --Russ |
Yup, looks normal to me.
thought so nail biting nerves racking but then again, duh a filter there for a reason. does it work both ways as to not ingest going in but oil wont get blown all over either.
dunk a shain my fine sirs |
I've seen a lake of oil in the U tube. When the motor sucks oil through to the cylinders it lowers the effective octane so detonation can be an issue.
Various schemes to rework the PCV flow seem to do a good job at stopping the oil. |
i do have erratic idle start the car 1050ish 2/3 sec intervals 875-900ish like dozen times down up down up bout a minute ... before finally going to set 950. if i excelarate the process by rev/gas pedal steady 1200 or so for 15-20 secs steadies out faster and idles right.
it looks like its time for a oil change!
I probably have the cleanest M28 engine in the world! I put the oil from this car in my lawnmower and 6.2 kw generator. The three run like tops... N! |
| All times are GMT -8. The time now is 02:33 PM. |
