ignition key positions
Ok here is a strange one.
1987 928S4 I can turn the car off... ignition off... power off to everything except radio and pull the key out. So the radio is still on. Even if I get out of the car. But here is the strange thing. I can also turn the key to another position which turns off the radio and still pull the key out from this position. Is this typical? |
my 82 does the same...i have left the radio on all night, at times
first have you checked the ignition switch on the back side of where the key is inserted?
The screws might be loose. If its tight then you may have uncovered a failing ignition switch |
Ok how does one take out the switch? also what screws loose?
No thats a problem, something isn't right.
Key should only remove in the 0 position - everything off Position 1 accessories & radio Position 2 ignition on Position 3 Starter Alan |
I have seen the key be able to be removed from the lock cylinder in other than off positions, either the key is worn or the lock cylinder is worn or both. Try spraying some WD 40 into the ignition cylinder not much.
Also try another key |
| All times are GMT -8. The time now is 08:47 PM. |
