toofast928's Avatar
WTB 84-85 MTM Flywheel, for Megasquirt
100 tooth for 5 SP.
Tony B
1982 Blk/Blk
5.0L Hybrid
Blown 10 psi 500 HP
Old 08-29-2009, 04:22 PM
Do you mean 85-86? Why the 100 version? The 60-2 is more universal.
BTW. I can mount timing teeth on a flywheel if you need. I just made fixtures to add the teeth to an early flywheel so one could have the lighweight double disc on an S4. I also do that for my own aluminum flywheels so it's no big deal.
Mike S.
79 928 Racer 427ci 32v 640WHP
Old 08-29-2009, 04:40 PM
toofast928's Avatar
Mike I have the duel disk clutch so looking for 84-85 flywheel. Where could I find the timing ring?
Tony
Tony B
1982 Blk/Blk
5.0L Hybrid
Blown 10 psi 500 HP
Old 08-29-2009, 05:25 PM
Here's an early flwheel I just added a timing ring to as well as drill for the S4 dowel.
I have the timing ring cut from non alloy plate, chock full o' iron for the sensor.
It's heated and 'shrink fit' to the flywheel, it's not going anywhere.
Since I spent the time to make tooling to install it with the missing teeth clocked relative to the dowel, I would be happy to do this as a service
$100 to add a timing ring to a supplied flywheel.
Add $20 if a dowel hole is needed.
BTW, that's with a 60-2 form. I don't see any reason to not use that and it's already proven on my 7 litre car.
Mike S.
Old 08-29-2009, 05:54 PM
toofast928's Avatar
I got it, .............PM you soon
Tony B
1982 Blk/Blk
5.0L Hybrid
Blown 10 psi 500 HP
Old 08-29-2009, 06:28 PM
You have to advertise more Mike. Way More. Cool stuff abounds. I have a toothless wheel I will have you do this to. I also have an 86 flywheel as well, if I take the 100-1 off, can you put a 60-2 on?
Old 08-31-2009, 09:19 AM
Yes B'! I'm working on a website to sell this stuff now. There's really no other way to go about it. I want to offer the flywheel service along with all the other bits I've been making, it's really a variety. I have camshafts, stud kits etc starting to accumulate here and nobody knows about it.
I'll do the 60-2 if you'll send the flywheel to me. It should be striaghtforward and I'm willing to adapt to be able to do the same for others.
Mike S.
Old 08-31-2009, 11:07 AM
Network Native
Danglerb's Avatar
Ebay can be an easy way to advertise, even for services.
Old 08-31-2009, 05:10 PM
