Order Online or Call:
888-280-7799
HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Click Here To Add Your Car to Our Owner's Photo Gallery!!!
Chat with other Users in the Chat Room NOW!!!
banner
The Pelican Parts Forums salutes the memory of Warren Hall (Early S Man), 1950 - 2008.  You will be missed by all... [Click for more details]
Help! Lost 1st 3rd and 5th gears...
Hi All
Something strange just happened while I was driving.
I tried to shift to 3rd gear quickly then usual so I might used more force then I usually do.
Anyway, I felt like something moved in the shift rod area and then I noticed that I can not put the rod lever to the 3rd gear! I set it into 3rd and the feeling is that the lever cant reach the gear completely since it bounces off to neutral gear.
This is also happening in 1st and 5th gear...
reverse, 2nd and 4th are a little closer to the center then they used to be.. but they work just fine.
What did I do?????!?!??
I assume that it can be adjusted...how can I adjust it back?
Porsche 928S 4.7L 1980 European redhead
Old 10-10-2009, 09:34 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Mrmerlin's Avatar
jack up the car and re center the rear shift connection you will need 2 13mm wrenches to loosen the bolt.
Make sure the trans is in neutral before you final tighten the collar.
The shifter should be just centered in the shifter housing you will need a helper to hold it there while you tighten the collar
1988 S4 Auto , Color is Elfenbein Perlglanz, with a full Pearl Gray leather interior
1986.5 928S Meteor Metallic, brown/tan interior, Auto
Old 10-10-2009, 11:06 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Thanks for the information!
Do you have a picture of that "rear shift connection"? is that the "shift Coupler"?
Shift coupler
Old 10-10-2009, 11:33 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Mrmerlin's Avatar
yes thats it
Old 10-10-2009, 01:29 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
thanks!
Old 10-10-2009, 02:05 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Well, it is much worse then I though
It seems that the reason why I lost the 1st, 3rd, and 5th gears are because of a broken guide rod!!!! As can be seen in the attached picture, it broke exactly in the welding to the metal plate (red arrow). ****!
When I came to my friend, the welding was already broken on the top and in the bottom it still held but then it completely broke
On Sunday (here it is a working day) he will try to weld it together without taking of the entire shift linkage since it is a huge work.
It seems that the pressure on the welding is on the top part so if he will weld it on the sides and on the top - without the bottom part, that can not be reached, it should hold.
I want to cry
Old 11-06-2009, 07:49 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Join us in Monterey for the Pelican Wine Tour & Canyon Run!  Click Here!
Mrmerlin's Avatar
Contact www.Roger@928srus.com, he has an updated fix to remove the front rod all together..
This removes the front rod, good luck
Old 11-06-2009, 09:31 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
Thanks I will write him right away!
Is that a common problem on this model?
Old 11-06-2009, 10:16 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
Mrmerlin's Avatar
I would not say common but your not the first one to have this problem and this is the reason that someone has MFGd a new shifter mechanisim to get rid of the old unit
Old 11-06-2009, 03:09 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
Fabio421's Avatar
Just weld it and be done with it. Mark Kibort on Rennlist had the same problem in his race car. He welded it in place and it held fine.
1984 928's w/ 5 speed Smoked Quartz Metalic
1982 928's Turbo w/ 5 Speed Platinum Metalic
1978 Euro Widebody w/ 5 speed Guards Red
Old 11-06-2009, 07:00 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
Mrmerlin's Avatar
Fabio there is a new shifter assembly that removes the front control rod all together, this makes shifting more precise Roger sells them
Old 11-06-2009, 08:28 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
Fabio421's Avatar
This dude is in Israel. The shipping and duty will be astronomical IMHO. If I were him I would weld it and go on with life. In fact, if mine broke here in the states I would probably repair it.
What is this replacement you are speaking of? Do you have pics or an explanation of what is changed? I would like to hear about it.
Old 11-07-2009, 04:57 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
Do you have feedback on our recent forum upgrade?  Click Here!
Mrmerlin's Avatar
the new part is actually mounted into the shifter housing and then the shifter is then connected via Heim joints to the rear rod.
Roger sells them
Old 11-07-2009, 05:00 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #13 (permalink)
Fabio421 is right. I will weld it and hope it will hold...for now it seems like the best solution.
Old 11-07-2009, 09:31 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #14 (permalink)
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.1
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright 2009 Pelican Parts - Posts may be archived for display on the Pelican Parts Website
One of the largest message boards on the web !
