-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Remanufatured Alternator Readings - Need Input! (http://forums.pelicanparts.com/porsche-928-technical-forum/507891-remanufatured-alternator-readings-need-input.html)
MPDano 04-23-2010 03:30 PM
Originally Posted by bwmac (Post 5313353)
Delco is the company that builds electronics for General Motors. You can go to any auto parts store (with your Bosh Alt.) and tell them you want a chev alt with the same mounting placement in 100 amps or more. they will more then likely sell you a standard 110 amp alt.
I was going to rebuild my bosh but now that i see this thread I will do the swap to the chev Alt.
I have done this to many fords and implement equipment before. They are a good replacement.
Theres already a write up on the Delco Swap with nothing but good results. Also, my local 928 buddy did it in his 79 928 with the same great results. I shoulda just followed him, but really wanted to try and make this work.
MPDano 04-23-2010 04:23 PM
Here's a write-up by Rjm65
Porsche 928 Forums dot com - View topic - Delco Alternator Replacement
bwmac 05-13-2010 08:44 PM
well I got tired of trying to find a delco that was bigger then the bosch that I took off.
So I bit the bullet and bought the 200amp. just over $700 with shipping. that hurt:eek:
Danglerb 05-13-2010 10:23 PM
Maybe you did find one, just paid $700 for it? ;)
Take some nice close up picts of what you get.
MPDano 05-14-2010 05:07 AM
I sure hope it's made of Unobtanium for that price. :eek:
Maleficio 05-14-2010 06:57 PM
I hope his grounds are in good shape. :D
It would suck to find out that the grounds were bad after spending all that dough.
Landseer 05-15-2010 03:16 AM
I just bought a Bosch factory rebuilt unit to replace my 86. Its 115A. Cost $257. Got it from Advance Auto, next morning delivery. (would have been less expensive from my normal source, but I needed it in hours). Wife and daughter got stranded in Va Beach. Got a call at night, two of them stuck in stop and go traffic for miles on entrance to a tunnel, with all dash lights flashing --- I knew this was alternator failure and hoped the battery would hold-out long enough. (Nice houses, wish one was ours, will never happen.)
FYI, this is the second time for the dash-flash deal. First time, while flashing, car running, I tapped the old Bosch twice with a hammer and heard it engage & the dash recovered. Bought us about a month. Before replacing this, after driving 3 hours with a load of tools in the other car & with the fresh alternator in a box, I repeated the tap deal with the BFH laying on the driveway --- same result. But it was time to replace, so I did that.
Also note, this alternator actually came from an 85.5 944, we had swapped it a couple years ago during an unrelated electrial witch hunt.
http://forums.pelicanparts.com/uploa...1273922161.jpg
http://forums.pelicanparts.com/uploa...1273922176.jpg
Maleficio 05-15-2010 03:32 AM
I wonder how much trouble it would be to replace the harness?
Landseer 05-15-2010 03:59 AM
Why?
Maleficio 05-15-2010 05:34 AM
Originally Posted by Landseer (Post 5351399)
Why?
28 year old wiring wrapped around a super-hot motor carrying the most intense load of all the circuitry. :)
harborman 05-15-2010 05:37 AM
Try one of these 350 amp jobs!
http://forums.pelicanparts.com/uploa...1273930661.jpg
MPDano 05-15-2010 08:11 AM
Dang. I sure wish I had a nice big and flat driveway like yours :(
Landseer 05-15-2010 11:22 AM
This is my daughter's prospective in-laws house.
It was, however, and excellent driveway to work on! Smooth finish, cool, stable.
MPDano 05-15-2010 11:28 AM
Heck, I'll Marry the Guy if your Daughter doesn't ;)
My Sloped Driveway gives my Wife a Heart Attack every time I work under my car on it. :eek:
Maleficio 05-15-2010 12:12 PM
Park perpendicular and jack up the low side. :)
Landseer 05-15-2010 12:19 PM
At least its not gravel like mine.
bwmac 05-15-2010 05:06 PM
Ya Mal that is always in the back of my head, but with half the dash and engine apart waiting for parts, and knowing that a large stereo with 3 - 800 watt amps is on its way, I thought I could use the extra juice. there is no core so I will buy a diode/req/bng kit for the old one, rebuild it and put it on the shelf incase I need a spare sometime.
Maleficio 05-15-2010 05:59 PM
Yep, your gonna need a lot juice for all those amps. Why so much wattage?
harborman 05-16-2010 04:24 AM
There are going to be a lot of deaf, hearing em-pared people around from listening to car stereo's at 189 DB in their cars!:eek:
