Order Online or Call:
888-280-7799
HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Click Here To Add Your Car to Our Owner's Photo Gallery!!!
Chat with other Users in the Chat Room NOW!!!
banner
The Pelican Parts Forums salutes the memory of Warren Hall (Early S Man), 1950 - 2008.  You will be missed by all... [Click for more details]
coolant leak question
Hi all, im a new 928s4 owner with limited knowledge with these cars. I have a coolant leak, not too severe but its there. Its dripping just above the front of the oil pan almost dead center, right under the pulley. Im assuming its the waterpump? Hows my assumption? lol
Thanks to mrmerlin for addressing my last post regarding the calipers,t.i.a for those who reply
Old 11-16-2009, 06:22 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
sounds right
1983 928 s automatic
Old 11-16-2009, 07:24 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Network Native
Danglerb's Avatar
Check for other potential spots like the coolant bridge, but yeah the water pump sounds likely it usually has a weep hole so its easy to see the seal is failing.
Old 11-16-2009, 09:00 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Petie3rd
Mrmerlin's Avatar
if you have a leak thats centered on the oilpan then that indicates a leaking waterpump . BUT first you should tighten all the clamps on the front of the engine sometimes one of these can also leak and give the same indication.
To see the weep hole on the pump requires at least the DS timing cover to come off then and inspection mirror inserted near the underside of the waterpump pulley to see the hole
1988 S4 Auto , Color is Elfenbein Perlglanz, with a Pearl Gray leather interior
Old 11-17-2009, 04:14 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.1
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright 2009 Pelican Parts - Posts may be archived for display on the Pelican Parts Website
One of the largest message boards on the web !
