ps pressure hose rebuild?
Can I have this hose rebuilt like I had my oil cooler hoses rebuilt, or do I have to buy a new one? I have read on here that I can rebuild the return hose, but what about the supply line?
1982 928 S Euro 5 speed
Old 10-02-2010, 11:33 AM
I had the supply line to the rack rebuilt by the same shop that did my oil cooler and trans fluid lines. They also rebuilt the return from the rack to the cooler but I could not use it. The hose section between the hard line from the rack and the cooler changes diameter. The cooler side hose end is larger than the other side, probably to reduce the fluid velocity through the cooler and allow more time for heat transfer as well as reducing pressure before return to the reservoir. The shop did not have any suitable hose that changed diameter, so I had to buy that section new.
Old 10-02-2010, 12:47 PM
Thanks for the help.
Old 10-03-2010, 04:34 PM
