My sunroof is stuck on one side
My sunroof is stuck on one side but goes back just a little bit until it stops... Tried to disasemble the mechanism but found out that it was welded on to the actual body.
Anyone know about any tricks?
Porsche 928 -82 One owner family before us!!!
Porsche Boxster -97 Arctic Silver
Porsche 996 4S -02
Porsche 928S Euro -81
Old 01-14-2010, 07:21 AM
Petie3rd
Mrmerlin's Avatar
remove the sunroof motor cover then the 2 nuts that hold the transmission to the transition tubes pulling down the transmission and slide it off the motor you will see the drive gear if its damaged then you need another transmission if not then one of the transition wires may have a broken end.
Remove the inner liner of the sunroof, 3 screws along the front edge ( loosen them 3 turns), pull the front edge down and slide it forward,
(This has to be done with sunroof open a bit , so the transmission has to be out of the way)
Look at the WSM for further adjustment procedures
Old 01-14-2010, 08:16 AM
Thanks! Will get on it as soon as I can! Thanks again!
Porsche 996 4S -02
Old 01-16-2010, 05:21 PM
