Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 928 Technical Forum
Recovering dismantler
neil30076's Avatar
Blower motor resistor pack - where is it!
On my 84 S, exactly where is it ? The blower motor only runs on defrost, console is out and the switch checks out OK, so i'm looking for the resistors!
Neil
81, 86 928 widebody.
1929 Model A Street Rod 270hp, V6
Land Rover Discovery
Bayliner Ciera 2655
Old 01-15-2010, 12:23 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
neil30076's Avatar
Bump - Merlin, someone please tell me where this darn part is!
Neil
Bayliner Ciera 2655
Old 01-15-2010, 02:14 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Banned
Normy's Avatar
Look under your hood. Now, near the windshield, you will find a thin black plastic "tray" that covers the wiper motor. There is a rubber seal that holds in down at the engine side, and some clips at the windshield side. Remove the rubber seal, and carefully pull the tray from its clips and remove from the car. Now, looking at the wiper motor, look just to the left- there is a square aluminum thing; this is for the air conditioner. JUST TO THE LEFT OF THIS is the resistor block. It is an electrical connector with two screws.
NOTE! VERY IMPORTANT! To remove the resistor block, you have to remove the connector first. But the resistor block is mounted INSIDE the air conditioning duct. If you remove those screws without attaching a string or vice grips or some other method...It will FALL INSIDE THE DUCT and you will wind up using your entire repartoir of profanity several dozen times while you attempt to retrieve it!
[guess how I know this!]]
Anyway, good luck!
N!
Old 01-15-2010, 02:24 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
neil30076's Avatar
Normy, thaks, by tracing out the wires thats what i figured, but i wanted to get someone to confirm - i've owned a 928 since '82, and never been down this path :-)
Neil
Bayliner Ciera 2655
Old 01-15-2010, 02:32 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
928 S4 Service - John Pirtle
Follow this link. It has some pictures.
look on the left side of the page, under HVAC, click blower motor.
Chris
86.5 928 Indy Red/Black, A/T, 118,456 miles and counting
Old 01-15-2010, 03:02 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Petie3rd
Mrmerlin's Avatar
the resistor pack is rather easy to retrieve all you need is a long wire with a hook on the end of it.
Once you remove the screws the pack will drop into the well but it wont go far, you can try to hook the wire onto the pack prior to removing the screws use the wire through the pack hole to reposition it along with a set of needle nose pliers to grasp one of the pins
^^^ Stan ^^^ 2011 BMW K1300S Magma red
1988 S4 5 sp, Black / Black leather/ Carmel carpet
Old 01-16-2010, 07:33 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
928: Serial Enabler
If you buy a new one to replace it, it may require that you switch a couple wires.
84 was NLA last time I replaced it.
Newer versions are wired differently and require adaptation.
84,85,86 928 cars
Old 01-16-2010, 09:19 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
928-Electrics Guy
Alan in AZ's Avatar
Whoa on the resistor pack....
If the fan does run on DEF but doesn't run on high (4) on the switch - it isn't the resistor pack or the fan motor.
You have a problem with the switch connector or the feed to the switch... don't mess with the resistor pack - its a waste of your time...
Is your blower relay and fuse good?
Alan
1994 928 GTS Black/Black Manual
Old 01-17-2010, 07:22 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
neil30076's Avatar
Thanks Alan, after looking at the diagram I came to that conclusion as well, so i'll probe further. Blower runs fine with slider control all the way to right, defrost - but not at all on the switch.
Neil
Bayliner Ciera 2655
Old 01-18-2010, 08:10 AM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Petie3rd
Mrmerlin's Avatar
pull the HVAC head out and verify the connector with the round pins is connected
Old 01-18-2010, 08:59 AM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
neil30076's Avatar
Stan, The whole center console is out, the plug was connected, I plan on tracing down the wiring shortly - doing intake/vacuum lines, Injector hoses etc R&R now, then onto electrical - got window working, door locks, electric mirrors all ok, sun roof is jammed - need to remove motor / gearbox etc. ABS light stays on - thats on the list also ++ who knows what!
When i bought this car i was not working - now going back to full time :-( , so now have a reaL sense of urgency to complete - need to deliver car to my daughter in South Carolina in first week of May!
Neil
Bayliner Ciera 2655
Old 01-18-2010, 09:06 PM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
Petie3rd
Mrmerlin's Avatar
make sure to replace the vacuum pods since the console is out
Old 01-19-2010, 05:57 AM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Formerly from Bannlist
MPDano's Avatar
I think what Merlin is trying to say is replace the Diaphragms (if available). Complete Pods are lot more expensive. I know I did get a quote for Roger on those and there is an expensive diapragm in the set.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior
Porsche928Forums.com (NOW Mobile Enabled!)
Old 01-19-2010, 06:30 AM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
rjm65's Avatar
Easy test to see if it's the relay, try the defroster relay in the fan (believe it's XXI and XXII) and see if that makes a difference.
Old 01-19-2010, 07:12 AM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
