ABS Warning Light '87 928
The ABS warning light on my '87 928 S4 is on. It came on shortly during a recent rain then went off when the streets dried out. It came on again during more recent rains but now will not turn off.
Does this mean I need a new ABS control module? Is there such a thing?
Does anyone have any ideas on how I fix this problem?
The car has 101,000 miles.
Thank you.
Old 03-01-2010, 06:29 PM
The Stick
RKDinOKC's Avatar
Does the ABS work? It is probably just a wheel sensor gone out.
Richard aka "The Stick"
06 Cayenne S Titanium Edition
Old 03-01-2010, 06:52 PM
Petie3rd
Mrmerlin's Avatar
check the power wire next to the power steering reservoir disconnect the battery first as its hot.
Do you have a fender block off plate in the front left fender?? There are 2 relays on top of the ABS unit , you can pull them and see if they are working.
Check the fuse panel for water and inspect the fuses clean them with an eraser same goes for the relays , and smell them for burns/melting any indications of heat open the relays.
Check the connectors at each wheel and inside the engine compartment for frayed wires/disconnected wires
Old 03-01-2010, 07:09 PM
