Ball joint blow up
Right ball joint on' 83 28 broke in my friends driveway. Ball joint completly severed as the rubber broke. Has any one tried the rebuild kits. I heard they save time and don't require the control arm to be removed which I hear can be a pain. Is this true?
Petie3rd
so what ball are you talking about upper or lower??
If its the upper them Motorsports sell rebuild kits if the lower then just buy the steel version and replace it . If your lower joint failed then you will also need atleast one new eccentric along with the joint to effect repair
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
its the lower ball joint. The rebuid kit is for the upper....?
Petie3rd
for the lower part you just buy a new BJ
and remove 2 19mm nuts to install it along with a new eccentric talk to your parts seller to confirm what you need
Yea but that could cost a lot if your married
![]() I just changed both of mine and rebuilt the uppers with the 928 motorsports kit pretty easy to do just had a problem on one side were the pin was seized in to the spindle. Found out my car had been hit because all the passenger side stuff was the new style spindle vs the driver side and the older style spindle.
'82 928 '86 951(RIP) '90 944 S2 Cab (RIP) '92 911 C2 |
To get the lower ball joint off you might have to use a special puller. Don't use the fork, it just messes things up and may not work. Save yourself time and frustration and borrow a puller from the auto parts store. Takes less than a minute to separate the BJ with it; not kidding either, less than a minute. Looks like a standard for, except it has a third piece that screws down on top of the BJ "pin" and pushes it out.
1982 928 S Euro 5 speed |
Forget my description; a little off. Here's a pic.
I own one of those just forgot it at my other house (74 miles away) when I did the ball joints today.
it is a cool tool that is for sure
Not sure if the sizing is correct but Harbor Freight sells a very similar tool for $20.
- Harbor Freight Tools - Quality Tools at the Lowest Prices ![]() |
It works great on Mercedes tie-rod ends too. :-)
thnxs for pics.....ball joint went in fine w/o problem...used a fork...had no problem...
Must be nice. NOTHING on my 928 has wanted to come off easily; everything seems to be welded into place and is a huge PIA to get off- rear cam seals, pinion on steering rack, ball joints, etc., etc.
