VDO Part Numbers?
Is there a website that can convert the VDO Part Number to a Porsche number? I want to make sure I am getting the proper Cluster Plate and Clips, but the numbers don't match up to a Porsche #.
Cluster Plate shows 88311033 Clips that hold PCB Connectors 81 119 024 Any suggestions? |
can you add any more info about what these parts are for??? did you search Bosch and VDO cross ref charts
Hi Merlin,
Yes, the plate is for my Gauge Cluster. It's the piece that all gauges mount to. The 3 clips clamp the connector to the Printed Circuit Board. I couldn't find a Bosch or VDO Cross Ref Chart anywhere. |
call 928 International they may have the parts or know where to get them, possibly used
I was able to peel off an old sticker of the Company that converted the Speedo from KPH to MPH and the Part Number shows as 928 641 103 30 I do not see that number anywhere on any of the big Vendors. The 64 "1" may be a different number since it's was scratched a little.
| All times are GMT -8. The time now is 12:00 AM. |
