928 dyno tuning, reading spark plugs, cleaning injectors.
Hi Guys, I discovered something I need to share.
If you recall I was still tuning my 928 before the '09 OCIC show & when changing my spark plugs, I discovered that cylinders 2 & 3 appeared to be running lean by reading the spark plugs. Because of the placement of these injectors in the middle of the rail, and that the new Bosch 044 pump was now sufficient for my fuel needs, I suspected my fuel injectors & declined they dyno portion of OCIC event. Well, I got a call this am from the injector rebuilder who does my injectors as he finished up inspecting/flowing/rebulding the 30's that were in my car at that time: #2 & 3 were only flowing 30% because of baked on carbon from excess fuel during tuning. Im very careful with my engine oil changes and reduced interval changes when tuning, so I'm not worried about my engine/oil. I believe this accumulation of carbon occured over time. Now that I have that set back rebuilt, I'll replace them back into the car again so that they're nice & fresh before my final dyno tuning. |
| All times are GMT -8. The time now is 09:18 AM. |
