-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Speedometer Circuit? (http://forums.pelicanparts.com/porsche-928-technical-forum/531037-speedometer-circuit.html)
bwmac 03-18-2010 07:23 PM
Hey MPDano, where did you get your Printed Circuit Board
see my post here
http://forums.pelicanparts.com/porsche-928-technical-forum/530864-why-would-someone-scratch-circuit-board.html
MPDano 03-18-2010 09:13 PM
see my post here
Mine is an early OB Circuit Board which I got from 928 intl. You may want to contact them to see if they got your model. I believe I paid $101 for mine.
MPDano 03-18-2010 10:11 PM
I posted mega pics of the process here:
Porsche 928 Forums dot com - View topic - Pics of my First 928 and Current Project
JhwShark 03-19-2010 08:55 AM
Originally Posted by MPDano (Post 5244499)
Ding ding ding!!!! You are the $$ winner! Removed the sensor with a 10mm socket and cleaned the sensor and Divet where the sensor lives with a wire brush and steel wool. Now "EVERY" Gauge on my Cluster works perfectly for the 1st time since I started this Project.
Do you have an accurate Voltage reading in the Pod??
Jon
MPDano 03-19-2010 10:39 AM
Jon
I haven't compared to the hot post or battery yet, but it reads a little over 12v on the volt gauge. I will do a more in depth check this weekend. Just glad that I can actually see how fast I am going.
I think the best thing is to get a 3rd party gauge and mount it.
MPDano 03-19-2010 10:47 AM
Also, my odo reset button got jammed (click, click, click) this morning and reset the reading for mileage, but didn't reset it right. Numbers are not a zero, etc. Do I have to open the Pod again to try and unjam it? I tried to hit the reset button multiple times but it's not moving.
JhwShark 03-19-2010 11:12 AM
Did you replace the spedo gear when you where in there? You may have some debris (possibly from degraded spedo gear)...I really don't remember how it actuates..just guessing.
Jon
MPDano 03-19-2010 03:32 PM
Jon
Yeah, the infamous disintegrating gear has been replaced almost a year ago. My problem is the reset button didn't put the odometer in a straight zeros line (if this makes sense) and now it wont move forward. If it's not one thing, it's another :confused:
Mrmerlin 03-19-2010 03:33 PM
you have to take to pod out to fix the odo reset linkage
MPDano 03-19-2010 03:37 PM
I was hoping you would tell me to "take the car up to 95mph and it will break the gear free or something." I'll probably break something else removing the Pod again. Just my luck :(
rjm65 03-19-2010 08:48 PM
Did you disconnect the odo reset button?
What became of the wiper fuse issue?
MPDano 03-20-2010 07:38 AM
Gonna work on that today. My coworker miraculously put my Euro Signal Stalk back together. I'm gonna put the CC Computer back too and see what happens.
MPDano 03-20-2010 01:50 PM
Ok guys! Total User Error (ID10T). I was wondering when I was putting the Cluster back together, the halves didn't snug up. The Reset mechanism needs to be in a certain position before the halves are put together. On the back of the cluster, you can see a small hole that the mechanism has a pin that goes through it. Put it back together and hit the Reset and walla! It all went to zero's as it should. Took it for a drive and now my Odometer advances perfectly. Absolutely everything in my Gauge Cluster is now working as it should. Yessssss
MPDano 03-20-2010 01:54 PM
Also, figured out my Wiper Switch issue too. Looks like the guy who worked my Air Conditioning last year smashed some of my wires next to the Wiper Motor (Expansion Valve Replacement) . I opened up the insulation and lo and behold, there were some shorting wires. Fixed them up and resolved my Wiper Switch fuse blowing and my Cruise Control Switch malfunction. I got's the Cruise Control now! Thanks rjm65, that Capacitor fix worked on the Cruise Control Computer too.
MPDano 03-21-2010 12:22 AM
Here is where the electrical short was:
http://forums.pelicanparts.com/uploa...1269156135.jpg
rjm65 03-21-2010 12:48 AM
That would be THE infamous flux capacitor.
