-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Amazing!! wp/tb project done (http://forums.pelicanparts.com/porsche-928-technical-forum/533425-amazing-wp-tb-project-done.html)
lfausty 03-27-2010 08:10 AM
There were times, garaging the pcar 82us jan-mar, i would have given anything to hear its mighty roar (moan,scrape). Boogied right along. But...
front to back clutch fan lube, rad flush, belts, airpump,oil pump, cam seals, rebuild tensior,arm,water pump. Whoo hoo
Amazing valves lifters seating operating nicely, sooo quiet, and the ride way better glide, some hp improvement. Not the strong pulling hps those were already there just much much better use of them.
A happy project done for the pcar. The Pcar says a SWEEEEEET!! Tanx.
HAHA issues, i got 3 where absolutely nothing was wrong garaging in jan
Headlights lights dont come on, second time around with them
radio wont turn on, pos one no antenna inst yetjust disc play
blower 25a fuse its third meltdown
Maybe these got a jolt when bat reconnected?
lfausty 03-27-2010 10:04 AM
oh yeah crank nut torgue how many ft lbs on 82us to put it back on. 218?
gotto get belly pan back on and using the under car angle to torgue the bolt now and forget whats ft lbs its torgued to , since its being driven prob a good idea
harborman 03-27-2010 10:52 AM
The harmonic balancer is torked to 218 ft. lbs. I rented a tork wrench that went to 250 lbs.
Great on doing all the work. I did almost of the same here last month. Not so bad a job with help from the guys here.
Please don't use so many abbreviations in your text. I hate text messaging!!!
Anyway, it sounds like you did a nice job!!!
mitsy 03-27-2010 11:57 AM
quality job pal hope im nextSmileWavy
lfausty 03-31-2010 07:37 AM
blower decided to work yeah since first was complete 25a fuse blow and then blew again then was time to do the taking of it out lubing project another fuse and awesome. so down for few winter months must be slow to move the cold lube but works great again
radio take pside console and pulled fuse blown , new fuse, works great
headlight after going through system issues project , new relay, again they didnt work
knowing the relay has its own issues ALWAYS PROPS TO MRMERLIN its coming apart as its the contacts 3 in there that wont illuminate the clicks are always there at relay and power but that relay sure is fussy when it comes to kickin the lights on. working great.
Always props to EVERYBODY
Maleficio 03-31-2010 08:38 AM
Are you trying to say you got your lights working with a fresh relay? :confused:
lfausty 03-31-2010 09:47 AM
No i got my old one working , after this "fresh one" doing the same thing, figured its cleaning not shot parts. Left the other "fresh one " in went back to the old one cleaned and switched it out and there working. So ill clean the other one too and have it too use. Probably in five minutes LOL
