-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Stock OB & S4 Caliper Brake Line Threads? (http://forums.pelicanparts.com/porsche-928-technical-forum/535121-stock-ob-s4-caliper-brake-line-threads.html)
MPDano 04-05-2010 11:59 AM
I was just wondering if they are the same. While I was doing a conversion, I might as well do the Steel Braided Brake Lines as well. Thoughts?
tlsmith1999 04-05-2010 12:46 PM
From memory, doesn't the OB brake lines screw directly to the calipers, and the S4 use banjo bolts? I would doubt the thread size would be the same. Either way I would suggest buying new (S4 style) brake lines as part of the upgrade.
MPDano 04-05-2010 02:34 PM
Hi Tim,
So if I just buy S4 Steel Braided Brake lines, then the "other end" should couple right up, correct?
