E-brake doesn't click or hold
Not the biggest of deals since I have an auto... but it would still be nice if it worked properly. When I pull up on the e-brake, it engages the brake and it does hold, but it won't stay. There are no clicks at all. I've searched and see instructions on how to adjust the tension, but not specifically the problem I'm having with it not holding. If anyone knows how to fix this, please let me know.
I don't think the clicks are an adjustment issue. It will be in the hand lever assembly. I am sure something is broken or fell out of place. I would open up that cover and investigate.
On my 79 that had sat for a while, the ebrake had the same problem. Taking the handle apart and cleaning the moving parts inside it fixed it right up.
| All times are GMT -8. The time now is 09:37 PM. |
