Rockin' NW Arkansas
firefighter7128's Avatar
Send a message via Yahoo to firefighter7128
Need Sunroof help
My motor seems to be out. When i hit the button the gear moves VERT slightly but the roof does not move at all. I assumed it had a manual overrides to started spinning the screw. I thought the screw came out to reveil a hex bolt but that screw does not. It is very hard to turn to open or close. Now that the rain is coming i cant seem to close the roof. The screw head is starting to strip.
Ideas?
Matt
1986 Porsche 928 S - Daily Driver
1984 928 S - SOLD, 1986 944 S - SOLD, 1988 944 S - SOLD
Old 04-16-2010, 04:59 AM
stepson's Avatar
Could be the screw is too tight for the motor to turn it.
Old 04-16-2010, 09:14 AM
cwiert's Avatar
Did you test the motor by taking it off the gearing of the sunroof? See if the motor works without any resistance. If the motor works fine that way, maybe you just need to take the gear part apart and clean out all the old gunk and re-lube.
If you can't close the sunroof with the manual override screw, something must be binding up somewhere.
'88 Porsche 928 S4 - LSD - Sold
'88 Porsche 944 N/A - Sold
Old 04-16-2010, 10:32 AM
american-kiwi's Avatar
there is a manual override tool for the sunroof...
John .........
1978 Porsche 928 5sp LSD
1982 porsche 928 5sp LSD
Old 04-16-2010, 10:31 PM
