harborman's Avatar
Relays
I have had several problems with the panel relays sticking. I noticed there are maybe 6 or 7 of the same type (53) being used and the OEM cost is about $8. One of them did go bad on me. I was able to modify one from the local parts store that worked on the Fog lights. It seems it may be worth while to at least replace all these cheaper ones and be done with it.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 04-21-2010, 10:45 AM
Network Native
Danglerb's Avatar
Replace all the cheap ones, and minimum clean all the contacts of all the relays.
Old 04-21-2010, 10:57 AM
tlsmith1999's Avatar
Roger sells them for $5. 53 relay at 928sRus
Tim
White '89 S4 A/T, Blue Int
Kaschmirbeige '78 5spd, Cork Int - Featured in High Heels & Hot Wheels 2010 calendar!!
Petrol Blue '79 EURO 5spd, Black & brown Pasha Int
Old 04-21-2010, 11:05 AM
SharkHead
JhwShark's Avatar
H-man,
Yes with the relays good ones are best.
It is worth exploring the cause of the sticking...you do not want to go through this again. I found that I had a leak in my rear q-panel window seal as well as the hatch latch seal. These caused water inside the car at the tire well. How I found my cause...this winter I went to start and no go. Pulled the pas. carpet up and noticed condensation on the relays and sticking relays. I could jump the relays and make them work but not with the ig switch?? The front was not leaking and I was confused until I decided to look deep for the where...I have corrected the leaky old seals and replaced the hatch latch seal. Then I found that I had corrosion in the front wire harness top section at the 14 pin...
Jon
'79 928, 85k Opal Metallic
'99 BMW 540i, 97k Titanium
'72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga
Old 04-21-2010, 11:06 AM
harborman's Avatar
Originally Posted by JhwShark View Post
H-man,
Jon
The fog lights were the ones sticking. I think because they were hardly ever used. The car has seen little water especially in the last 18 years in storage. I don't see any sign of dampness near the electric panel at all. But I think I will replace all the cheaper relays anyway.
1986 928S
32 valve engine
Old 04-21-2010, 11:26 AM
harborman's Avatar
Muchas Gracias Signor!
1986 928S
32 valve engine
Old 04-21-2010, 11:28 AM
