mitsy's Avatar
injectors
decided to check the injectors just to make sure there were no duffers got them all out,bridged the pump and there are 5 of them have an intermittent spray pattern and then when you press the flap down more they just stop is this the injs or the fuel dist or both im clueless
1983 928s euro white
Old 05-04-2010, 12:54 PM
Network Native
Danglerb's Avatar
Swap the connections to a good and bad injector.
Old 05-04-2010, 09:28 PM
mitsy's Avatar
i gave that a go too but it seemed to be more or less the same,starts looking good then fires right out as it should then as i push down more it gets intermittent then stops altogether am i pushing too far maybe
Old 05-05-2010, 12:22 AM
Network Native
Danglerb's Avatar
Not driving it, check the flow pattern into a jar or whatever you did before, but with different injectors in a couple spots to see if its distributor or injector problems. Time and measure the flow at a fixed pressure might be good too, or just clean them all in an ultrasonic thing.
Old 05-05-2010, 01:40 AM
mitsy's Avatar
found it d old filter stuck in the dist man how good does pamela sound and go now
Old 05-05-2010, 12:47 PM
