I just made an estimate, an over-estimate. It's not too long, really. |
When it comes to wiring and cleaning use this stuff. Nothing better.
DeoxIT D Series and Deoxit Shield S Series https://caig.com/deoxit-d-series/ |
I cleaned all the ground points in my 928 and replaced the ground strap from the battery to frame. It had developed internal resistance. I would suggest replacing that strap. |
Those undercar ground cables are not insulated so that moisture/water will not be held in place, the water will be able to run out, and the ground cable will dry. Just an FYI. :)
| All times are GMT -8. The time now is 04:49 PM. |
