Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 928 Technical Forum
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
Formerly from Bannlist
MPDano's Avatar
OMG Gunar! Your almost there. Put batteries in the Video Camera!!
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior
Porsche928Forums.com (NOW Mobile Enabled!)
Old 03-04-2011, 07:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #481 (permalink)
928: Serial Enabler
Update????
84,85,86 928 cars
Old 03-05-2011, 11:06 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #482 (permalink)
gbgastowers's Avatar
It started on the first try.... Praise God! It doesn't smoke at first but when it starts to warm up it makes some white,blueish smoke. I need the fuel pressure gauges to adjust it. I drove it around the block several times and it will not idle or respond to idle screw. It also is not making much power under load. I will also check the timing. Coolant is coming out of the reservoir but I don't know where. I still see plenty in the reservoir so maybe it was too full? It shifts smooth and reverse works with backup lights. The only gauge I have that works is oil pressure. I am working on uploading some videos so stay tuned...
82 Euro S 5 speed, sport seats,Moss Green
Old 03-05-2011, 11:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #483 (permalink)
video 1http://www.youtube.com/watch?v=3kL9cudjHmA&feature=player_detailpage
Old 03-05-2011, 12:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #484 (permalink)
928: Serial Enabler
Yesssssss!
84,85,86 928 cars
Old 03-05-2011, 12:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #485 (permalink)
YouTube - Porsche 928 Euro S(1982 5SPD) FIRST START (part 2)
Old 03-05-2011, 12:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #486 (permalink)
MPDano's Avatar
What is the procedure for breaking in rings?
Old 03-05-2011, 02:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #487 (permalink)
I thought it was to keep varying the rpms. Nothing constant for any extended period.
Old 03-05-2011, 02:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #488 (permalink)
Awesome!!! Long road...
Old 03-05-2011, 03:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #489 (permalink)
Pete R's Avatar
engine break in per 928 motorsport.
ftp://12.234.229.133/installpdf/enginebreak-inprocedure.pdf
sorry it won't link, wtf.. but it's on their site
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 03-05-2011, 03:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #490 (permalink)
928: Serial Enabler
Next update needed, Gunar! Everything ok?
84,85,86 928 cars
Old 03-06-2011, 06:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #491 (permalink)
Drove it to gas it up with 93 octane. No power under load, stumbles and dies when I let off the gas. I set the timing and pulled a plug that showed too rich so I'm going to back the mixture up a bit. Engine bay is bone dry except for maybe some coolant getting out of the reservoir. The gas tank is leaking a bit since I filled it up. Still need to get it in tune. It felt pretty solid as far as suspension-Kinda like a 30 year old sports car. The steering rack reseal I did is holding up also and the steering feels proper.
Old 03-06-2011, 06:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #492 (permalink)
MPDano's Avatar
You need those get some CIS Pressure Gauges Gunar. I have a feeling your stuff is way off. I'm pretty sure you did some adjustments to your A/F with the 3mm Allen? Correct?
Old 03-06-2011, 06:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #493 (permalink)
Yes- I will get the gauges. I have adjusted the a/f mixture. I jumpered the fuel pump and turned the mix to just when the injectors started singing then backed it off a bit. After checking the plugs I backed off a bit more.
Old 03-06-2011, 08:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #494 (permalink)
I am having my gauges repaired by Nichols in Greensboro,NC so I have the pod apart. I had the charging system checked at the parts store and of course it said I needed a new battery and alt. The battery that was in there was too small anyway and I bought an alt. with a lifetime guarantee. The test still said I was not charging after all this so I suspected the exciter circuit was not closed. I have pulled the diode out of the cluster and connected the 2 wires that go to it together with the diode and will have it tested now and see what happens. I am driving the car with the pod out and will put it all back when the gauges are finished. I also found a disconnected plug off the female side of the ignition switch plug that I don't know if it's supposed to be connected somewhere or what it does. Any help would be much appreciated. Gunar
Old 03-25-2011, 08:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #495 (permalink)
MPDano's Avatar
Almost like driving without a Dash
Old 03-25-2011, 08:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #496 (permalink)
MPDano's Avatar
That plug looks familiar, but can't quite figure out what that goes to.
How's the car running??
Old 03-25-2011, 08:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #497 (permalink)
928: Serial Enabler
Yes, UPDATE.
Please.
Jadz928 and I were talking about your project last weekend while we worked on the perl white 87 car.
Major-league compared to what we were doing.
84,85,86 928 cars
Old 03-25-2011, 09:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #498 (permalink)
SharkHead
JhwShark's Avatar
That plug fits into a male receptacle on the bar from the steering column to the ig switch location. It plugs in orientated up such that the receptacle is under the bar and you push the plug up into it.
You can not see where it goes on your pic, but on my car it is located about where your removed switch is located (on the underside of the bar) or in that area...the length of the wires should help you find the plug. It is for the Parking lights.
'79 928, 85k Opal Metallic
'99 BMW 540i, 97k Titanium
'72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga
'74 1/2 MGB , 125k Sahara
Old 03-25-2011, 10:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #499 (permalink)
Still not running right- maybe 60% going down a hill. I have 047 injectors coming and CIS gauges ordered> Fuel Injection Testing Tools GM T.B.I. system - Bosch - eBay (item 260753897830 end time Mar-17-11 20:15:47 PDT) and >Mercedes Benz Brass Upgrade 8 Fuel Injectors CIS 85-92 - eBay (item 380325210441 end time Mar-24-11 06:52:38 PDT)
I pulled the plugs yesterday and #6 was totally new looking like nothing was happening in there so I switched the injector from a good cylinder and checked the spark there- Seems to be running a little better but a long way to go to final tune. It starts easily but 1st and reverse grind when car first starts so I have to kill it and restart the engine in that gear. After about 2 minutes it shifts into those gears perfectly. I took the WUR apart and cleaned it. Everything looked clean and intact in there. Spark is strong but maybe the no power under load,backfiring has something to do with the charging system. It revs fine when not under load. No smoking but strong smelling emissions. If I get all the basics in good shape I may take it to Motorworks for the final tune. I have it lic. plated and insured but still need safety inspection. I had a dual in dual out Magnaflow installed which took care of the loud exhaust problem.The right side exhaust is showing heat marking while the drivers side is not. Don't know whats up with that.
Old 03-25-2011, 11:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #500 (permalink)
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
