Power steering
I have no power in the steering, There are bubbles in reserve container , Is there anywhere bleed screw or how to bring to life steering which has been not used for 10 years please ?It is 928 model 1979
Old 05-09-2010, 12:18 AM
Petie3rd
Mrmerlin's Avatar
you could try opening the 2 lines at the bottom of the rack before you do this buy 8 new sealing washers 4 for the first time you reseal it and 4 if this doesnt work.
Open the lines then drain the rack turn the wheels back oand forth a few time till all of the fluid is out then reconnect the lines using your old sealing washers .
refill the reservoir with fresh fluid start the engine and turn the wheels back and forth about 10 times. make sure the fluid level stays topped to proper level, the fluid will be a lite pink with all of the air . after it sits for a few mins the fluid should become solid deep red.
If this doesnt happen then your pump may be going bad.
Inspect the rack boots for leaks drain each boot from the inner edge where its attached to the rack report back how much comes out
Also make sure the belt tension is correct
Old 05-09-2010, 05:18 AM
