I agree with Alan in AZ now that you explained it more. I'm a mechanic and I would bet that it is a bad ground. Check the easy one at the right side of the engine, underneath. For some reason that is the most common problem with this type of electrical issue. My kid once install 2 batteries in his car to stop the stereo from causing the flux Hope some of this helps, check out the video |
Alan |
| All times are GMT -8. The time now is 03:26 AM. |
