need help! NLA distribution piece from AAR
I am looking for 928 110 439 00, PET describes as distribution piece. It is the plastic hose union/connector from Aux Air Regulator to Air Guide Housing that has three smaller hoses joining at this piece, two on one side and one on the other. I believe for 78-79 only.
Anyone had to re-work the routing, the t-joint that is broken goes to the AC valve (hanging from the crossbar)on one side, the other side of this AC valve hose goes to a T-union in the hose from AAR to Start Valve Piece. This set up is reconfigured in later models, and obviously you would have AC. So, if any 78-79 folks have taken out your AC you may have this piece Thanks, Jon |
bump...
Anyone! I can replace the hose from AAR to Air-Box with new bulk and splice in three T-connections for my 3 hoses that come off of the P# in question. But that is not original... In the mean time I will try and source other hose fittings for the 1" main with three 3/8" (I know metric is stock; this is just for reference size). Maybe I'll find a 2-way T (two 3/8 off of the 1' main...then add a standard T-fitting further down line; just not a lot of room for the fittings??? |
928 International has it for $12
http://www.mailordercentral.com/928intl/prodinfo.asp?number=928 110 439 00 |
Thanks Leo!
Interesting, I previously ran the number Sat and came up not available. Tom has 2 and one of them is on the way... |
Did you run the number with the spaces? If not, the spaces need to be there. That's how 928 Intl store is categorized. You would think the data backend would accpet both ways.
I usually do...but then it was a Saturday
Thanks |
| All times are GMT -8. The time now is 12:49 PM. |
