Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 928 Technical Forum
Maleficio's Avatar
Jacobs Electronics Ultra-Coil works great!
Yeah, I know, do not EVER install a non-stock coil or you'll fry the ECU.
I felt the copper plugs were not firing at full force in the lower revs, so I found a coil from Jacobs, bought it for $50, installed it today, and I couldn't be happier.
Will post pics tomorrow.
Old 05-26-2010, 05:21 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Network Native
Danglerb's Avatar
Now any kind of engine running problem and you get to wonder, is it that non stock coil I used? Cause maybe it will be, maybe it won't.
Years ago I put a non stock "hot" coil on my car, and it ran great, no change really, but it still ran, until about a year and half later the engine started randomly stopping and if on the highway so the rpm didn't drop too much, starting again. Coil checked out fine, but turns out it was known to fry ignition switches and I think even started some car fires due to the higher current draw.
Old 05-27-2010, 02:55 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Network Native
Danglerb's Avatar
BTW there is no "full force" on spark plug firing, either the fuel mixture ignites or it doesn't, there is no better or worse. The factory system is guaranteed to fire under all conditions every time for 50k miles or the dealer has to fix it free, so its pretty robust under any remotely stock application.
You might be even happier with a full MSD ignition system.
Old 05-27-2010, 03:02 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Maleficio's Avatar
I hear ya. I think my coil was worn out, and the Jacob's is not exactly a hotter coil, just a modern coil. Check it out.
Amazon.com: Jacobs 380876 Ultra Coil, Universal: Automotive
1982 Porsche 928, Auto, 4.5
http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945
Old 05-27-2010, 04:37 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
harborman's Avatar
I would be concerned about the current draw of the coil and what the ignition system was designed to handle.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L
Old 05-27-2010, 05:12 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Maleficio's Avatar
Seems a worn out coil would draw more current than a new one.
Old 05-27-2010, 05:24 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
harborman's Avatar
Yes, it may even destroy or damage the electronic system. But, I would not exceed the ratings of the original coil, especially on the primary side, especially if it's transistor driven.
1986 928S
32 valve engine
Old 05-27-2010, 07:17 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
Maleficio's Avatar
It appears my old coil was an electrical black hole.
The car's running lots better, and my voltage reading is actually stable now, and never drops below 13 on the dash gauge, whereas before it would fall to 10 volts at idle.
The coil says Accel because they bought out Jacob's. It's a Jacob's coil branded Accel.
Old 05-27-2010, 09:10 AM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
Network Native
Danglerb's Avatar
I get known good and guaranteed used coils from 928Intl for $20 each, and don't have to think about whether or not its the coil causing any troubles.
Not posting this to chew on you, just so that you don't lead anybody else down a bad path. Porsche built these cars as 150 mph daily drivers, so when you tinker with their design, use alternate parts, working fine for a few days or weeks around town isn't proof of goodness.
Old 05-27-2010, 10:01 AM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Maleficio's Avatar
So I guess I should install a Bosch coil even though the Jacob's is working great?
Jacob's is the only company I trust for aftermarket ignition components. I've had bad luck with coils from other companies.
If this coil screws up my car in any way, I'll tell everyone immediately what I did, and how it went wrong, just like I did with the Pulstar plugs that I fouled with Amsoil Powerfoam.
Old 05-27-2010, 10:29 AM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Maleficio's Avatar
By the way, the screw-on terminals on the Beru plug wires are very cool. I've never seen a design like that before.
Are the threaded terminals available without the wires?
Old 05-27-2010, 10:30 AM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
Maleficio's Avatar
Been running the Jacob's coil for eight days without a hiccup.
Old 06-02-2010, 03:20 PM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
80 928
Im ma gonna use the coil offen my 'ol John Deere!
-K
Old 06-02-2010, 06:37 PM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
Network Native
Danglerb's Avatar
As long as its running fine, maybe not, but it would be the first item I would change if any troubleshooting was required. Second would be the normally rock solid ignition box in case the coil damaged it.
Old 06-03-2010, 09:26 AM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
ASE Master Tech - 25 yrs
larrym's Avatar
FYI - some good discussions of Jacobs vs Bosch coils, etc on Shoptalk forums Shoptalkforums.com • View topic - Proof that the Bosch Blue Ignition Coil is WEAK!
and
Shoptalkforums.com • View topic - MSD 6A and Bosch blue coil?
If it works, take it apart and find out Why.
Old 06-07-2011, 11:46 AM
  Pelican Parts Technical Article Directory    Reply With Quote #15 (permalink)
Maleficio's Avatar
Old 07-12-2011, 11:56 PM
  Pelican Parts Technical Article Directory    Reply With Quote #16 (permalink)
Network Native
Danglerb's Avatar
The links refer to VW's back in the 70's still using mechanical points in the distributors, and I don't agree with what they have to say even in those conditions.
Old 07-14-2011, 12:51 AM
  Pelican Parts Technical Article Directory    Reply With Quote #17 (permalink)
Engineer of profanity
924CarreraGTP's Avatar
Don't sweat it dude. My 928S has had a Jacobs E coil for 2 years. It runs great. However, my 944 boiled one but it was used out of a junk yard. The Jacobs coil has an application for the 944. The 928 with a similar engine bank and fairly similar electronics should do fine.
Old 07-14-2011, 03:23 PM
  Pelican Parts Technical Article Directory    Reply With Quote #18 (permalink)
Architecture & Porsche's
I tried both a pair of Crane units & a pair of MSD units (coils too on both) back in 1999: fried all 4 units, even though I verified my wiring feed (coil feed) from both MFR's. Both MFR's replaced the units for me, but there was no way either of those were going back on my 86.5 car.
Porsche Club Racing National Scrutineer
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 07-15-2011, 06:46 AM
  Pelican Parts Technical Article Directory    Reply With Quote #19 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
