ok.... I think I found right hose... I DL'd the PET from porsche site.
part# 928 110 177 02 is that correct?http://forums.pelicanparts.com/uploa...1276196955.jpg |
Yes, that is the hose from AAR to Start valve. On a '79 engine there is a "T" fitting spliced in-line. The smaller T outlet has a hose go to one side of the AC valve.
The other side of the AC valve goes to a spliced in Hose fitting with Three "T's" between back of AAR and Air Box (underneath the pas side intake tubes). These (on '79 configuration) three "T's" from this splice fitting...As mentioned, front pas side goes to AC Valve, Opposite fitting goes to driv side hose to intake plenum (there is another join there) both of these hose "T" fittings are same size. The third "T" is pas side larger hose to a plastic vacuum valve (forgot the function name) that has another hose same size going to the sidewall and a small red silicon hose on top...these "T" can get brittle, 928intl has the fittings. While you are inspecting the AAR and hoses behind it and beneath the intake tubes...look very close at the small hose underneath the AAR that comes out the water bridge behind where the Rad hose goes in. This is usually neglected and degrades and leaks, it is second rad overflow hose that joins a primary overflow hose before the overflow container (it is above the plastic vacuum valve discussed in the paragraph above). Jon |
Thanks Jon,
Does anyone have some closeup photo's of engine bay that I can reference. Also, I'm not sure if you can see in photo a braided line on left side that has a burn hole or possibly worn. What part is this so can order both at same time? Thanks |
a closeup of hosehttp://forums.pelicanparts.com/uploa...1276201190.jpg
Buy the fitting # 928 110 439 00 (confirm the number on the 928 shopping page) as it will crack when you try to remove it. It is best to take the AAR off to re-fit this one and redo the 3 out hoses I discussed previously. The main run from the fitting to the air-box needs the intake tubes removed. This part of the run could wait...more to disassemble in order to do it. |
I do not have photos right now...I'll try to find them and post. I replaced the hoses and fittings we are discussing.
From your engine pic there seems to be some hose where fuel line/tube should be; the one going into the front top of the plenum above the cold start valve. This appears to go into the WUR, but the WUR does not look like it is configured right! :eek: |
Check all the hoses from WUR if hard and/or brittle buy and replace. |
I'm sure previous owner was messing with WUR and may have hooked up wrong or moved as it is very lose and not bolted down tight. I will have more time this weekend and may be able to get hoses locally. Again, Much thanks!
Carey |
The previous owner appears to have taken the whole intake off, painted it etc., and ended up selling it as does not start. You have to figure they have tried all the simple things to get it running. I would be checking everything, not fixing this or that until it sort of runs.
Here's what I did with mine. i used Engine High Temp Wrinkle Finish Paint. I believe made by VHT. http://forums.pelicanparts.com/uploa...1276263214.jpg http://forums.pelicanparts.com/uploa...1276263223.jpg |
Wow that looks awesome. We actually got it started and running for a few seconds and then it dies... You can hear several vacuum lines leaking and seem to have a gas leak, oil leak. Not sure from where. So I think taking spider off is an excellent idea. I love the pics any other assembly or re assembly pics will be very useful.
Thanks everyone. I will keep posted and add pics as I go. Carey |
Hey sent you a pm.
Roger Is my go 2 guy for these cars, he is a walking encylopedia Pelican has a lot of parts that you may need and they are fast POrtland Ken makes the Porkentensioner and he is awesome. That is the single most awesome mod I have done to my car at this point. (i plan on getting more of his products). U may want to get a set of his lift bars also. Best of luck! Car looks nice, but u have some work ahead of you. |
Hey Carey, good luck on the Porsche I am from Harrison Tn. I own a Porsche 928 1980 Euro black on black I have been working on for almost a year, do have some bits an pieces if you should need something. You are close enought to drive here about hour an half, well good luck, Steve
Steve, Thanks for your reply and everyone else......I look forward to seeing your 928 sometime. Good to know I have someone close to pick their brain... ;) Planning vacation so my project is on the back burner till after I get back.
I hope everyone has a safe and fun 4th of July Carey |
Just an update for everyone.
I have hit a roadblock on my 928. I was waiting on title from previous owner. It seems he has been jerking me around. And as each day passes it looks bleaker that i will ever get title. He said he has to go back through import company to get paperwork. Well its been about 3 months. I am hesitant to put any money in it till i have title. So if anyone has any suggestions that would be great. If not i may just sell it as parts car. So if anyone is interested let me know. |
I'v used www.its-titles.com in the pase for a motorcycle and it went smoothly. I have also heard of others using www.broadwaytitle.com though I do not have any direct experience with them.
If you got a bill of sale from the owner you should be able yourself to seek the title from the DMV. Especially if it was previously registered in Tennessee, and maybe too if it came from another state. You can also go down the path of pursuing the owner for fraud and basically forcing the issue. There are several ways to do it. You wouldn't want to find out the car had "other" ownership after you sold it or its parts. No title / freeze in your tracks til you get one. But if you have BOS, you should be in excellent shape. If neither, you will need to persuade him or maybe start engaging sheriffs and the like. No nonsense approach is the only way to go on this stuff.
There's no way I'd ever buy a part from you now that you've said you don't have a title to the vehicle. BTW, I'm from Tennessee and have cleared several titles there in past years with BOS only. |
| All times are GMT -8. The time now is 04:29 PM. |
