2Quick4u928's Avatar
Oil Priming Possible (87-91) Motors
Am used to U.S. muscle cars when building motors...On my 88' S4, is there any oil priming that can be done on a motor that has been sitting for a few years prior to ectual engine turn-over?
Thank you in advance!!
Pat
So. of the Rio Grande
Long distance relationship w/my 88' S4 5-Speed Bi-Turbo Widebody In Work; Italy
Old 11-17-2009, 06:50 AM
Not unless you remove the timing belt.
You could remove the spark plugs and turn it over to prime if you feel that's important.
Mike S.
79 928 Racer 427ci 32v 640WHP
Old 11-17-2009, 07:19 AM
Network Native
Danglerb's Avatar
Pull the plugs, squirt in a bit of oil or fancy stuff like Marvel Mystery oil, let it sit a few minutes and then turn the motor over a few times by hand, then crank til you see oil pressure, then put the plugs back in and start it. I had lifter noise on one of mine that lasted about half and hour, but got less and less.
Old 11-17-2009, 12:44 PM
Appreciate the response guys, will complete. The Marvel M. Oil may be a bit tough but will attempt to network to see what I can come up with. Will keep you all posted, thanks again!!
Pat
Old 11-19-2009, 07:55 AM
SharkHead
JhwShark's Avatar
You mentioned that you have not started it for a few years...
What conditions was it stored in??
Temperature range?
Have you done anything regarding your gas in the gas tank? Any seperation of water from gas...
I would be interested in hearing what you do or dont to about the gas based upon your conditions.
Jon
'79 928, 85k Opal Metallic
'99 BMW 540i, 97k Titanium
'72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga
Old 11-19-2009, 08:31 AM
Hey Jon,
Actually had swapped motors due to what I believe was a flex plate/thrust bearing sesure which apparently locked up the motor. Took a bit of time to get the ball rolling to begin the swap out due to family issues and the lot.
everything has been completed now, is only the installation of the cool air duct for the alternator remains. Have opened all the major fuel lines around the motor and blew the lines out with compressed air as well as towards the fuel pump in the tank. This weekend will jack up the opposite end and drain the fuel, add some high grade fuel then flush again and physically verify the tank and clean manually if needed. Lastly will add the high-grade again as with fuel additive and some STP gas treatment. After this will do as the guys meantioned above then pray the ole girl fires up hassle free!
Pat
Old 11-20-2009, 12:26 AM
SharkHead
JhwShark's Avatar
Originally Posted by 2Quick4u928 View Post
Hey Jon,
Great, that should do it.
Let it run...
Old 11-20-2009, 01:03 PM
Thanks for the response.....car has been sitting for 3 to 4 years now. Emptied the gas (7 gallons plus or minus), a few days ago...Gas normal smell, looked pure and remained color (Blue) for E.U. high octane. Ran gas treatment through the system and drained. Wife called, left clamp onto pump inlet line but the fuel continued a steady drip and the hot trouble light was not too far away. While talking, was thinking of a bright flash & heat, but was fortunate hehe.
Will add some new fuel next week and drain, then physically check inside the tank (If I can get the locking collar for the sensor removed). Add more high octain with fuel additive and see what happens. Felt confident enough with the old fuel, will dump in with my new fuel in the BMW with some gas treatment, believe ok....will soon see hehe.
Pat
Old 12-04-2009, 12:51 AM
Pat
Old 12-04-2009, 01:48 AM
Network Native
Danglerb's Avatar
I'm thinking about making a wrench/socket to fit the sensor ring. There may also be an actual Porsche part as well, but I have heard of using a T fitting for PVC pipe and cutting notches etc to fit the ring.
Old 12-04-2009, 09:27 AM
bwmac's Avatar
Just through I'd give my 2 cents (6 months late)
I believe it is very important to prime the oil pump before you try and turn it over.
I did the mains with engine in the car and just installed the T belt last night but forgot to spin the oil pump and I am going to back step, take the belt off the gear, remove oil pump gear put my air drill on the shaft and spin it up.
When the drill loads up then I will know the bearings have oil before i start dragging metal to metal crank over the bearings.
Names Brad, Canada, Fort McMurray.
Car is a 1989 928 5L AT from Japan, 17" rims, 95,000 k vin#WPOZZZ92ZKS842476
Old 06-13-2010, 08:36 AM
