interior/exterior temp sensor
Hi Guys
I was wondering, if one of those sensors is not working correctly, will it affect the temperature control slider that control the air temperature that is coming out of the vents?
How can I check the interior/exterior temp sensors to verify that the are working correctly?
Thanks for the help!
Porsche 928S 4.7L 1980 European redhead
Old 06-08-2010, 08:14 AM
Petie3rd
Mrmerlin's Avatar
to check the sensors usually the outside one will fail at its connection point due to corrosion but connect an OHM meter and blow on the sensor you should see a change as the temp warms, if you dont get any than the sensor is bad , the inside sensor usually doesnt go bad so check the outside sensor first
Old 06-08-2010, 02:58 PM
Thanks but is it true that if the outside/inside sensor is faulty then I am not able to control the air temperature (step motor) inside the car using the temperature control slider?
Old 06-09-2010, 12:52 AM
stepson's Avatar
IIRC, you will only get full hot or full cold out of your system regardless of where you put the slide control.
Old 06-09-2010, 08:14 AM
Thanks!
Old 06-09-2010, 08:39 AM
cwiert's Avatar
just a follow up question...
on a left side drive car, the outside sensor is inside the passenger wheel well, right? and i need to remove the wheel to get to it?
'88 Porsche 928 S4 - LSD - Sold
'88 Porsche 944 N/A - Sold
Old 06-14-2010, 06:12 AM
Petie3rd
Mrmerlin's Avatar
the sensor is under the left front fender its attached to the airduct that come from the alternator
Old 06-14-2010, 07:12 AM
