91 928 dash msg, "Differential control inop"
I hope someone may have seen this problem before.....
after starting my display shows "Differential Control off" and then Brake service required. the dealer says both are fine and operational.... I have noticed that when I run the AC I get low voltage and I am wondering if this is result of low voltage to the control module. I only have 23,000 miles and the car runs great otherwise. Thanks for any help Daryl |
when was the last time you flushed out the PSD unit?? what is the charge rate at the hot post with the engine running?? use a volt meter to find out
| All times are GMT -8. The time now is 04:57 PM. |
