79 928 shift linkage issues
I have a 79 928 with a 5 speed I drove it one day and the next day lost 3 & 5 gear. It seams the shifter dose not travel the distance today. I will in gage 1st but not 3 or 5th. Any one had this issue or the best way to adjust the linkage?? Any pointers on best approach to this?
Old 07-25-2010, 01:14 PM
stepson's Avatar
get under the car and check out the rear shift linkage. Are the bushings FUBAR or are they tight? Should be pretty easy to tell if everything is tight there.
Next, get under the car and check the front ball cup. Pretty hard to see, but if someone else is in the car and shifting the gears, you will probably see the shift rod moving. Follow it to it's end and the front ball cup is located there (providing it's still connected). If it's not, buy the insert, pull out the old insert, and replace. Use a ratchet strap to pull the cup and new insert back onto the ball.
Good Luck!
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 07-25-2010, 01:42 PM
thank you for the info !!! I will give it a shot.. Is the a trick to remove the boot over the linlage?
Old 07-25-2010, 02:12 PM
stepson's Avatar
One time use on the boot. Lube the inside, but keep the outside dry so you can grip it. Just wiggle it off and when done wiggle it on. That's the worst part of the whole deal is jacking with the boot.
Old 07-25-2010, 02:23 PM
Kyle C
I didn't know it was possible to replace just the plastic insert in the forward shift socket. Does the same apply to '84 model cars? If so, where do you get it, mine needs replacing and I have been hesitant to spend $75 on an entire new socket.
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 07-25-2010, 03:50 PM
stepson's Avatar
Call Roger at Home - 928's R Us Online Parts Catalog
I believe he stocks them.
Old 07-26-2010, 07:27 AM
Thank you for all your help repair is done and it shifts betternthen ever!!!
Old 07-31-2010, 04:07 PM
Tags
928 5speed , linkage
