under dash roll switches ???
does anyone have a pic and know what the roll switches are under the dash.
There is one on the right and one on the left. The one on the right has 2 wires that go to it, a yellow/red tracer and a pair of yellows. (1 spade half way on switch & 1 near top of switch) I have checked the PDF manuals but can not find them. I checked the PDF wiring diagram but can not find them. Any one have these open to view |
The left one ( part nr. 928 613 121 01) is the instrument dimmer rheostat. The right one (part nr. 928 613 122 00) is an interval rheostat. The both hook up the instrument cluster wiring harness. The left rheostat
http://forums.pelicanparts.com/uploa...1278053334.jpg http://forums.pelicanparts.com/uploa...1278053377.jpg And the right rheostat http://forums.pelicanparts.com/uploa...1278053408.jpg Hope it helps, and let me know if you need more. K.c. |
Oh man, you couldn't make it any clearer. the yellows confused me.
Some day if we meet, I owe you. Thanks Brad |
You would'nt know if the cluster language can be changed to english eh :)
Nope - and I need it in Danish :)
Any time Brad, and I drink Ale when we meet. K.c. |
there may also be a small push button switch as well , Its black, this is for the hi intensity wiper/washer control its 2 black wires with very small connectors. Prior to connecting the rheostats remove them from the pod (unscrew the screw about 3 turns dont take it out) then slide the switch sideways to remove it take to the bench and test it usually they need some work to get them functioning
Great pics! Now this is how to answer a post.
Right switch controls time interval for windshield wipers in intermittent mode.
