Were do you install the rad flush tee
I was thinking of installing the flush tee in the front 1 inch hose that connects between the rad hoses.
what's your thoughts
Names Brad, Canada, Fort McMurray. Car is a 1989 928 5L AT from Japan, 17" rims, 95,000 k vin#WPOZZZ92ZKS842476 |
Petie3rd
in a word....dont.
if you want to flush the radiator drain it from the blue plug on the bottom of the passenger side then remove both of the radiator hoses and put in the hose, or you can remove the whole radiator from the car , if you want to flush the engine then you need to remove the block drains each bank holds about 1.5 gallons of coolant and add water through the top radiator hose connection to the water bridge.
^^^ Stan ^^^ 1988 S4 Auto , Color is Elfenbein Perlglanz, with a Pearl Gray leather interior, MOTORSPORT of UTAH X pipe 2005 Range Rover MK III, Giverny Green/ Oxford leather Lux interior, BMW 4.4i |
OK I have to ask why not? is it due to possible pressure damage?
I plan on running a can of 10 min flush through it to remove the rust, then flush it out with water till it runs clean, then drain and refill with aluminum compatible antifreeze.
928: Serial Enabler
Because they are all expensive custom hoses with multiple diameters and there are other ways to flush. Like drain, refill, repeat. Or 16 gallon shopvac on one big hose, flush solution / water on the other. You can pull 100 gallons backward through the thing as fast as you can dump the shopvac. Or combo.
There's also a stigma against cobbling them up or even, as you've seen, bypassing the WSM. Huge negative perception amongst the typical Porsche owners group I've found. (Though some of them sure love adding modified race parts). Do what you are comfortable with. Just expect negative reactions, like when you took the girdle off the block without removing the engine. Last edited by Landseer; 07-02-2010 at 08:05 AM.. |
Petie3rd
first of there should be no rust in the system as it had an aluminum block,
second the cleaner may damage the headgaskets and cause them to fail . a flush for the 928 should merely be, drain radiator and block, refill with distilled water drain and fill with your favorite coolant i suggest Zerex Zo5 coolant found at NAPA As an aside just adding a T isnt going to flush much as the block will be holding 3 gallons and the flush system wont circulate through the block so it drain the radiator and then both of the block drains first
^^^ Stan ^^^ 1988 S4 Auto , Color is Elfenbein Perlglanz, with a Pearl Gray leather interior, MOTORSPORT of UTAH X pipe 2005 Range Rover MK III, Giverny Green/ Oxford leather Lux interior, BMW 4.4i Last edited by Mrmerlin; 07-02-2010 at 11:59 AM.. |
I expect the rust came from the oil coolers or water pump.
I didn't use the flush chemical since the car is old and I don't want to cause a head gasket leak on our trip. pulled drains and let the water flow.
Flushing will not achieve anything unless you also remove the block drain plugs (two 13mm headed bolts on underside of the block).
I flushed my '87 repeatedly until it ran clear after failing to remove the block plugs. I used the radiator flush in a bottle stuff to run the car up to temp before draining and flushing. I also flushed using a hose pipe to keep the system full while the engine was running, so the pump circulated clean water through the block. Then I figured out how to get the plugs out (drilled a flat onto the side of the rounded-out head, and used a punch and hammer to get them turning). I was amazed at the huge amount of sediment that came out the block even after all the flushing.
Various manual S4's |
Petie3rd
that huge amount of stuff that came out was probably a good part of the exposed headgasket material that the cleaner was circulating around.
, so the gaskets are cleaned where the coolant flows, but now they are also thinner and quite possibly they will begin to leak in a short while. A leaking headgasket will first be noted along the top edge of the block along the V you may see a crusty white material along the edge of the gasket then you may have a cylinder begin to get coolant in the bore
