| john schlemmer |
07-09-2010 09:56 AM |
soild tranaxle mount up date for 5speed
hi everyone, everything thing seems to be good so far with rear solid trans mounts, the trans is a little more noisy.but i t dosen't bother me. you could that something like a small wet sanding block say 1/4 thick and cut to size ,and install it between the cross over and the mount. that would probaly soak up some of it. i left the front ones stock and right now have one plans to change them. got a question that maybe someone has some experiance with. will a 87 -95 flywheel bolt to my 82 4.5 crankshaft? also can i use a 78-86 t/o and guide on a 87-95 pressure plate? i see that the newer t/o bearing and guide is different that the one i have. thanks john
