Used ’81 928 Parts for Sale
Please drop me an email or PM if interested, I will send photos on request, Odometer shows 82k miles, not working when removed
…shipping extra--------------------------------------------------------------------------------
  1. Fuel tank As removed, clean inside, fittings not loose $100
  2. 5 speed transmission Thought to be “good”, PO said it works perfectly, but he lied about some other things too, will need to ship commercial freight $350
  3. Clutch plates, pressure plate, flywheel etc. Decent and very usable condition, dated ’86 so not the original assembly $200
  4. Instrument cluster, complete Needs odometer drive gear, some of the traces are in need of re-gluing on flex board where connectors join $100
  5. Front spindle left As removed from car, good condition with bearings $50
  6. Front spindle right As removed from car, good condition with bearings $50
  7. Upper front control arm As removed from car, good condition $25
  8. Upper front control arm As removed from car, good condition $25
  9. Pair of front plastic sun visors Brown, good condition except mirror is not perfect $40
  10. Lower front control arm, aluminum ball joint left side As removed from car, good condition $30
  11. Lower front control arm, aluminum ball joint right side As removed from car, good condition $30
  12. Transmission saddle As removed from car, good condition $50
  13. Rear quarter panel glass left side Has aftermarket sunshade applied, glass condition good $30
  14. Rear quarter panel glass left side Has aftermarket sunshade applied, glass condition good $30
  15. Door glass left Has aftermarket sunshade applied, glass condition good Sold
  16. Door glass right Has aftermarket sunshade applied, glass condition good Sold
  17. Window regulator with motor left side Needs pulley replaced, working when removed $30
  18. Window regulator with motor right side Needs pulley replaced, working when removed $30
  19. Sunroof drive motor No connector on wiring, working when removed $20
  20. Sunroof drive transmission As removed from car, working when removed $20
  21. Torque tube Shipping will be an issue, as removed from car, with shift linkage $50
  22. Bell housing As removed from car $50
  23. Lower clutch cover As removed from car $40
  24. AC condenser Was holding pressure when removed from car $45
  25. Radiator Shipping will be an issue, as removed from car, holding water under pressure $65
  26. Lifters (16) As removed, all seem ok $25
  27. Hood requires stripping and repaint White paint is heavily oxidized and is not the first color, no shipping $100
  28. Driver side door (left) requires stripping and repaint White paint is heavily oxidized and is not the first color, no shipping $100
  29. Passenger side door (right) requires stripping and repaint White paint is heavily oxidized and is not the first color, no shipping $100
  30. Leather power seats, pair Must be recovered DF sold $100
  31. LH computer Tested and working sold
  32. Ignition computer Tested and working sold
  33. Fuse and relay panel As removed, no burnt out wires or connections seen, some of the relay connection points have been hot… $70
  34. Front bumper, aluminum part only Shipping will be problematic $50
  35. Back bumper, aluminum part only Shipping will be problematic $50
  36. Bumper shocks (4) As removed $15 each
  37. Front stock sway bar Shipping will be problematic $15
  38. Back stock sway bar Shipping will be problematic $15
  39. Steering Wheel black leather, condition very good $100
  40. Front bumper cover, needs stripping Sold
  41. rear bumper cover, needs stripping $100
Old 07-17-2010, 11:15 AM
