-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Sensor Type (http://forums.pelicanparts.com/porsche-928-technical-forum/557002-sensor-type.html)
PorscheOwner 08-04-2010 04:28 PM
Sensor Type
Car Info: 1984 928
I am trying to find out what type of sensor the 928 has. I want to use my Apexi AFC NEO piggyback computer on the vehicle, but I need to know if it is compatible first since it is not specifically designed for any Porsches.
There are diagrams but I do not know which type of sensor is in it; hot wire, flap, pressure, or Karman sensor or none of them?
Reason: Chips are pretty much out of the question. Authority is a garbage chip(they haven't even emailed me back in over 2 weeks), since I have been reading that they run rich low end and lean high end and often fail inspection.
Danglerb 08-04-2010 07:40 PM
Air flow meter in a US 84 is a barn door or flap type, chips are soldered to the circuit board in the brains and nobody I know of has ever made a replacement chip.
Early cars do respond well to exhaust upgrades, US 85/86 manifolds, X or Y pipe, high flow cats and mufflers. Some people also report improvements with a hotter cam, 1979, a Euro S, or a custom cam.
PorscheOwner 08-04-2010 08:24 PM
I have the correct computer than. Does anyone have a wiring diagram for an 84 ECU?
Example: http://www.clublexus.com/forums/atta...i-430-ecu2.jpg
A diagram showing what each wire is?
Danglerb 08-05-2010 12:27 PM
Here ya go, more info in this thread.
L-Jetronic Connector Pin-out - Rennlist Discussion Forums
http://forums.pelicanparts.com/uploa...1281036420.jpg
