wills928's Avatar
compressor
is there any way to test an ac compressor once its off the car?
wjcoleman
84 928
1986 suzuki gsxr1397cc
"8's and lookn 4 da "7"s
Old 08-10-2010, 06:37 PM
Kyle C
Are you trying to test the compressor itself or the compressor clutch? Did you remove the compressor because the system was not working?
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 08-14-2010, 07:47 PM
wills928's Avatar
Clutch, I took it off a parts car I have
Old 08-14-2010, 08:29 PM
Put 12 V to the wire going to the clutch and touch the ground to the compressor body, it should snap in.
86.5 Porsche 928, 75 Porsche 914, 2.0, 2001 Boxster.
Old 08-15-2010, 03:54 AM
Network Native
Danglerb's Avatar
You would need a functional AC system with a drive belt to test it, which is why I wouldn't bother installing a unit that wasn't either rebuilt or from a known working car, and the second option is iffy. Good rebuilts are around for as little as $200 shipped, why risk the time and freon with a maybe ok and for how long compressor?
OTOH if I were to do it again, instead of a good rebuilt I would switch to a Sanden scroll compressor (newer type rotary thing).
Old 08-15-2010, 02:43 PM
