-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   how in the hell,,,,,,, (http://forums.pelicanparts.com/porsche-928-technical-forum/558972-how-hell.html)
wills928 08-15-2010 11:03 AM
do you remove the back seats from these 928's:confused::confused::confused:http://forums.pelicanparts.com/uploa...1281895364.jpg
mitsy 08-15-2010 11:31 AM
the bottoms of my seats were glued to the sound proofing and the backs have two torque screws at the bottom outside plate,put the seats forward to get at them
s928s 08-15-2010 05:23 PM
The seat bottoms are glued in. The folding seat back is removed as follows.
1. pull up rear cargo carpet.
2. Remove the 2 Phillips screws at the back corners of carpet.
3. remover the 2 6mm Allen bolts at the outer portion of the seat hinge ( You may have the move the seat hinge up and down for access to the bolts )
4 slide seat back towards the center post mount and lift up on the hinge side.
I hope this helps.
DAVID
