-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Blinkers no worky, solid light on dash??? (http://forums.pelicanparts.com/porsche-928-technical-forum/564073-blinkers-no-worky-solid-light-dash.html)
SharkTech 09-13-2010 07:59 AM
Out for my std rip through West Chester yesterday morning, my typical Sunday morning 30 mile drive.
Noticed that when I hit my blinkers on, the light just stayed green on the dash, until it clicked off after turn. No blinker when doing this. I checked while out of the car and when the blinker is engaged the blinker light is not actually lit, will not light at all, even if you manually click the blinker up and down, nothing.
Before I investigate, was looking for some possibly obvious from the guru's????
Thx, in advance.
1979 US 928, custom, but the blinkers should be of std factory engineering.
stepson 09-13-2010 09:14 AM
Possibly relay V (1H0.953.227) located on the bottom row on left directly next to big relay.
Does the same thing happen on both sides of the car? Do the turn indicator lights illuminate on the outside of the car, but just not flash?
SharkTech 09-13-2010 09:56 AM
Yes, both sides are affected the same. No, exterior does not illuminate when stalk is in blinker location, right or left, does not matter. Solid blinker light on dash, does not blink on and off, and again nothing outside of any illumination, etc, even if manually moved up and down.
Thx.
FYI,
This is what ya think I need???
Blinker Relay
stepson 09-13-2010 07:06 PM
Yes, that's what I think you need.
That is for sure what I would start with anyway.
SharkTech 09-14-2010 05:10 AM
Thx for the advice, Relay has been ordered.
I will provide feedback once installed.
ANGEL P 09-14-2010 07:37 AM
Do the lights flash when the emergency lights are engaged? If they work, that test would indicate a steering column switch or some other issue.
Hmmmnnn.........
The relays are simple devices that sometimes get a little corrosion between the contacts. Sometimes it is just the external contact pins. If sure it's the relay, you have nothing to loose but a little time by attempting to better the electrical contact. If the external pins seem fine, try removing the cover from the relay, delicately inspecting between the contacts and delicately cleaning them (did I say delicately?) with perhaps a strip of fine emery paper (#400 or finer) folded in half and dragged between the contacts (only once or twice so as not to remove any silver plating!) Finish by spraying with a little electrical contact cleaner and reassemble. Presto! A (perhaps) renewed relay.
Some of our relays are pretty common and may be available at a local auto parts store. I believe that I have obtained at least one at a common retail supply house.
SharkTech 09-14-2010 09:52 AM
Hmmmnnn.........
Good advice Allen, thx for the input.
If I were to miss the $16 I just spent on a new one I might try this but I will not, so awaiting the new relay delivery, sure this will do the trick.
jthwan22 09-14-2010 11:48 AM
if the relay doesn't fix it, look into emergency switch
MPDano 03-06-2011 03:39 PM
I see that this thread was not completed or answered and I am having the same issue. My Hazards work fine and blink but my left or right does not. Just a solid light on dash and no lights on the exterior.
Any suggestions?
Mrmerlin 03-06-2011 04:12 PM
try this
Hmmmnnn.........
baby shark 03-07-2011 12:04 PM
i had the same symptoms with my relay....it was an easy fix....Be4 I fixed it, i with hand signals...For a week i was still the "cool guy" with 928.....but also " the dorK" who had his left hand directing left or right when turning....anyways....it was the relay...I took it out, disassembled, and saw with the help of jewelers magnifying eye i have:), I saw the contact had to be resodiered...
MPDano 03-08-2011 05:48 PM
Ok all, got my OEM Blinker Relay from Pelican Parts and still the same symptoms.
1) Solid Light on Dash with "NO" external lights on
2) Emergency Flashers flash lights on Dash as well as working external lights
3) All Fuses look good
Besides replacing the Signal Stalk, are there any other suggestions?
neil30076 03-08-2011 05:53 PM
Leo, Sorry, no, except to agree on the signal stalk - but remove it first, figure out which are the directional contacts, and jumper them out to test / verify.
Neil
MPDano 03-09-2011 02:26 PM
I can always pull the Stalk from the Euro and give that test, but it's not at my house.
Are the Emergency Blinkers the same bulbs on the rear and front?
Also, are there any specifi ground locations that would affect just Directional Blinkers?
Mrmerlin 03-10-2011 05:51 AM
check the CE panel on the back for melted wires at the blinker relay if that checks good then replace the stalk and test it
MPDano 03-11-2011 05:15 PM
I put my Euro Stalk on there and Blinkers started working. I buttoned it all back up, tested it and same thing, solid light. Ok, pulled the long plastic cover and pulled a small wire that I plugged back in (piece looks like the odo reset on my Euro but it isn't on this year). Blinkers worked again. Put the plate back, did the test, blinkers work. Hit the Hazards, got blinking on both, turned hazards off, Blinkers back to solid.
I'm saying WTF to myself, so I plugged back in that little wire I disconnected and the Blinkers started working again. Buttoned it up again. Blinkers work.
Ok, now I just said "leave it all alone now!!"
MPDano 03-11-2011 06:14 PM
Well Hell, went to go get myself some Micky D's and guess what? Blinkers stopped working again. Got too dark. I'll tackle this tomorrow.
Any suggestions?
MPDano 03-13-2011 12:37 PM
Ok, figured this out.
Circuit goes through the Hazard Switch. I could get the Blinkers to work and then if I move the Pod around it would stop. Ok, I knew I had a bad connection somewhere.
I pulled the Hazard Switch and you can see some of the blades weren't connecting very well, so I used a small screwdriver to push them down for a better connection. That was it. All good now.
