On your ignore list
Crank seal removal?
Anyone have a good trick for pulling the front crank seal? Mine is really on good.
Petie3rd
take a screwdriver with a wide blade and drive it into the cutout on the relief of the seal bore.( about the 8 O clock position)
Drive it so it only goes about 3mm deep this will prevent it from damaging the crank , then pry it out from the side its made to be taken out this way, use a stone to dress down the seal bore if you make a burr with the screwdriver
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
On your ignore list
![]() Last edited by JE928sx4; 09-25-2010 at 02:48 PM.. |
928: Serial Enabler
Thanks for this picture.
Used this technique yesterday on an 87. The new seal got driven past flush, maybe by 1.5mm Are we ok with that? |
On your ignore list
I've heard that is bad juju, but wonder. Your biggest problem will probably be some weeping of oil that can be detected before anything major might happen. Monitor and react. If any leak develops it will probably develop over several years not right away and you can pull it again a few years sooner when you do your next TB change. The Crank seal is not a normal replacement item with TB/WP change unless you are anal. I'm guessing mine was the original when I replaced it......24 years later. From what I have observed it might wear a bit on the inner most edge as the crank spins if that is against it, but the wear you most fear is around the crank itself if the seal is at and angle. If not seated at 90 degrees to the crank it will wear unevenly and weep oil eventually.
928: Serial Enabler
We pushed it in too far and we figured we couldn't recover.
Part of the problem was I put assembly lube on the outside. We then made it the same recess depth around the perimeter. Maybe, due to the lube, I can pop this one out and refit. Thats probably a bad idea. We are waiting for a replacement crankgear. I'll see if we can get another one added to the shipment.
84,85,86 928 cars Last edited by Landseer; 09-27-2010 at 06:16 PM.. |
On your ignore list
928: Serial Enabler
Thanks for the contact for seals and the offer for the rear seal.
Just doing the front and will know in the morning if Roger can add this to the owner's shipment. I got tired and sloppy on the first install I guess.
84,85,86 928 cars |
Petie3rd
dont put anything on the outer edge of the seal it goes in dry the seal should be flush with the block if its lower that will also work
BUT if you put oil on the outer seal it could slip out
928: Serial Enabler
Gotta pull it and start again, then.
84,85,86 928 cars |
It is always good practice to position the seal a lttle further in than the original, the crank gets a groove worn in it and by repositioning the seal it will not run in the same groove as the old one, another fix is a speedy sleeve.
86.5 Porsche 928, 75 Porsche 914, 2.0, 2001 Boxster. |
