European Shark
riber.bentsen's Avatar
Unstable tachometer
Hi guys..
Weird issue for you all to solve
My rev counter has been acting up lately, as in not working When i get in the car, close the door and start the car, the tach doesn't work. However, if I wait and close the door after the car is started, the tach jumps up, and works just fine!
It also works if I close the door (with a bit of oumph) after the first procedure. And just like all other problems on a 928, it comes in periods..
What do you make of it all?
Thanks, Niels.
1978 Porsche 928 Euro 5spd. Silver metallic/Black
1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed*
Owning a 928 is risky business - but sometimes you just gotta say "what the fudge".
Old 10-23-2010, 08:41 AM
Petie3rd
Mrmerlin's Avatar
to fix this you need to remove the gauges and clean the back side of the connections to the tach and slide on connectors use an eraser to clean the surfaces
Old 10-23-2010, 10:12 AM
European Shark
Damn, I've been ignoring that 'pod for quite some time, but I guess the job is inevitable when owning a 928 :/
Old 10-23-2010, 11:32 AM
Kyle C
I agree with Mrmerlin - my speedo was intermittent, cleaning the cluster connections fixed it 100%. Sounds like you have the same issue.
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 10-24-2010, 07:28 AM
