1978 928 - 9288200072
Brake Pad light - Central Warning Unit
The brake pad light on the central warning system comes on every time I start my car and only goes out when I push the reset button. It has been this way since a bought the car a couple of years ago.
I have installed new sensors at each wheel and have checked the continuity at the fuse panel and the circuit is closed as it should be. I also checked the continuity at the central warning unit (connections 19 and 20 on the black plug) and it is okay also.
Looks to me like the central warning unit is not working correctly. Do I need to replace it or is there a way I can take it apart and repair this one function?
Occasionally all the dash lights do not go out when I start the car and I have to start it again.
Rick
(PS: interesting note - this is an early 1978 and someone indicated the early ones were hand built. The plugs on the fuse panel were all numbered with a marker and I wonder if it was done at the factory. The two plugs on the central warning unit are black and one of them has a yellow piece of thick paper glued to it to show it is supposed to be yellow.)
Old 10-11-2010, 09:48 PM
the control unit lives under the left foot rest assy. not a good enviroment to be in water,dirt ,vibration etc.. try and spank the control units and see if dash warning lights go on and off i have seen many contol units act up like this if it does you need a control unit have replaced many of those on that model. regards tom
Old 10-11-2010, 10:14 PM
928: Serial Enabler
Wow, that is an early one. (#6 has recently resurfaced and lots of current discussion on the early ones is happening)
Why not trace each of the sensor wires and wiring harness to the CE and the dead pedal using a voltmeter?
Through 84 the wiring plugs are hand lettered.
Old 10-11-2010, 11:23 PM
Thanks guys. I've ordered a unit off ebay. Hopefully that will solve my problem.
Old 10-12-2010, 07:32 AM
Well, my new control unit arrived and it did not solve the problem with the brake pad light.
I did a bunch of scoping with my multimeter and finally discovered that one of the brake pad sensors was grounded. The small metal spring that holds the sensor in place was touching the sensor wire. So even though there was a complete circuit through all the sensors, the control unit did not like the fact that the circuit was grounded.
I replaced the faulty sensor and everything is working like it is supposed to. This is the first time in over two years that I have not had to push the button to get the dash light to go out. I am ecstatic - hooorah!!
Rick
Old 11-01-2010, 08:10 PM
Petie3rd
Mrmerlin's Avatar
great, glad you got it figured out.......
now to clean all the fuses/relays and the 14 pin connector under the hood
Old 11-01-2010, 08:38 PM
I've already pulled and cleaned all the fuses and relays. The relay panel still looks like it is new. The outside of the 14 pin connector looks great, but I have not pulled it apart yet. I'll do that next.
Old 11-01-2010, 09:59 PM
928: Serial Enabler
A bunch of pictures of your 78 would be nice, just in general.
Lots of interest lately in the original configurations.
84,85,86 928 cars
Old 11-01-2010, 10:05 PM
Love to oblige.
It is an early 78 - the Central Warning Unit I just checked was dated 12/77. The car still has the original engine and tranny serial numbers. The speedo shows 71,000 miles (actually 114,000 km). It seems to be in clean original condition - I just put in new TT bearings and was surprised to see that the underside looks to have the original undercoating with good paint and very few dings (other than some $#%& from someone not lifting it properly on a hoist).
Here are a couple of pictures - if anyone wants to see any specific spots, I can take some and post them.
Old 11-01-2010, 10:35 PM
European Shark
riber.bentsen's Avatar
WAAAAAAAAAAAAUW!!!!!!!!!!
I'm speechless, and my keyboard needs cleaning now..
1978 Porsche 928 Euro 5spd. Silver metallic/Black
1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed*
Owning a 928 is risky business - but sometimes you just gotta say "what the fudge".
Old 11-02-2010, 12:46 AM
Recovering dismantler
neil30076's Avatar
Rick
FWIW - The usual cause of all the lights not going out when you start is a bad ignition switch - I've replaced a couple for this exact problem. Not an easy job and i would live with it - you have to pull the pod, etc to replace, and what is working now may not after!
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 11-02-2010, 07:03 PM
Thanks for the info Neil.
The dash light problem seems to have gone away - I installed the newer control unit and it seems to have solved the problem. I'll keep my old one as a spare.
I can see the ignition switch causing this problem. If I understand the wiring diagrams correctly, the problem might be between positions 2 (ignition on) and 3 (starter on). When you turn the key to position 3 to turn on the starter, the wiring diagrams show that it breaks the contact with position 2. If the contact with position 2 is not broken, the car will still start properly, but the dash lights will remain on.
Old 11-03-2010, 12:24 PM
neil30076's Avatar
That's correct, and if the return spring in the switch assy is weak, it hangs up between position 2 & 3 - and the lights stay on.
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 11-03-2010, 12:45 PM
Can you squirt oil/WD40 into the ignition keyhole to lubricate the whole ignition assembly to make it easier for the return spring to work? Or do you have to remove the ignition assembly.
Old 11-03-2010, 12:50 PM
Petie3rd
Mrmerlin's Avatar
you can spray some WD40 into the lock cylinder not much,
it will not lube the elex portion
Old 11-03-2010, 01:23 PM
JK McDonald's Avatar
Beautiful Car -
Hey vandenham, What a beautiful car - the interior has also obviously been well cared for and in great condition. A 5 speed to boot - Great catch.....
Michael
Old 11-06-2010, 05:47 PM
928: Serial Enabler
Well, inerxxl, try the english version yourself.
Then, after some practice, you might figure out where to post your advertisements.
84,85,86 928 cars
Old 11-08-2010, 05:30 AM
