Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Rear Hatch Defroster Repair
One of the soldered connectors on the upper defroster grid snapped off awhile back while I was removing the rear spoiler. As usual I have put off repairing it until I actually need it to work, it has been getting pretty icy lately. Can it be reattached?
'84 928S 5-spd, schieferblaumetallic over dark-blue/tan
Old 11-08-2010, 08:22 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Anyone?
Old 11-10-2010, 05:34 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Recovering dismantler
neil30076's Avatar
Check out : FindTape.com Search Results for 'copper tape'
They make a copper tape that will stick to the broken off connection on the heater element side and make an electrical connection.
Then, with this tape,
Try scraping back the remaining piece of the copper contact strip on the heater element end, so that it is accesible - polish it with a 600 grade paper so the foil is clean and use the new tape to complete it, and make a connection to the wire that broke off. When you have it working, build up around the joint with a good epoxy, so it does not break off again.
Good luck
Neil
Neil
928 OC Regional Rep - North Carolina
81 928, 84 928S Euro (Daughters), 86 928 ( Wifes)
Hyundai Sante Fe, Land Rover Discovery, Winnebago Brave + Jeep Wrangler, Proline 21WA boat.
Old 11-10-2010, 05:52 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
garylewa's Avatar
Go to: frostfighter.com and look up what you need; I have used their tab repair kit with excellent results; their prices aren't too bad either and the products are superb.
Old 11-10-2010, 08:03 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Thanks for the links, both methods sound like they should work. I will take another look at the broken tab to see whether or not it needs replacement.
Old 11-11-2010, 03:40 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
I actually heated the tab while holding it with a pair of needle nose pliers untill the solder was melting and then just pressed it back on to the spot it came off and it looks like new
Old 11-16-2010, 03:48 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
What did you use to heat it?
Old 11-21-2010, 05:25 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
