Clutch problem...
Clutch pedal woudlnt return all the way, eventually crapped out all together, cant engage any gear, obtained new slave cylinder, old one was leaking, mechanic says system still wont hold pressure, is it the master? and how hard is it to get to???
Sergio
Old 01-22-2002, 04:23 PM
Author of "101 Projects"
Wayne 962's Avatar
There are only three parts of that system, the master, slave, and the line that connects them. It has to be one of the three. The master cylinder is located underneath the pedal cluster on the driver's side. Should be easy to get to by removing the floorboard (might have to get to it from underneath - I can't recall off the top of my head...)
-Wayne
Old 01-22-2002, 04:37 PM
The master cylinder is in the engine compartment. It's not even slightly accessable!! Once you remove it; replace the blue hose that goes to the reservoir and make sure the pressure hose is good too.
Just remove parts to aid getting at the cylinder..some people remove the brame master cylinder (we don't) and the booster..
Be very careful not to cross-thread the pressure pipe.
Good luck.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 01-22-2002, 05:13 PM
still have scars from that one
Being a self proclaimed good wrench turner. I hope to NEVER have to do that again. You can pull the carpet back in the foot well to see if Clutch master is leaking. But getting into the engine compartment to RR the clutch master cylinder is a real pain.
I am living proof it can be done in the driveway put ear plugs on the kids to muffle the cussing.
Old 01-23-2002, 01:13 PM
