sun roof repair
Hey, board.
Does any one have the correct procedure to remove the headliner in the in 1984, porsche 928. Sun roof drops dowm but will not pull back when switch is activated. Sounds like the mechanism is running back and forth.
Can push up on sunroof as it comes to rest on the close position and it moves up and stays in close position. Can fix if I don't tear up the headliner trying to remove it. Could use some help?
Old 11-23-2010, 07:48 AM
you should crank the sunroof open, then there are three screws that attatch the sunroof headliner.
i removed mine and had it reglued, was not hard
here is the post i followed
928 AUSTRALIA - Tech Tips - Sunroof Adjustment
Old 11-23-2010, 11:54 AM
Network Native
Danglerb's Avatar
The grease on the tracks etc. turns to glue over time and needs to be cleaned off and relubricated with non dirt attracting lube.
Parts of this job suck beyond imagination, getting it all back together "just right". Take your time, repeat steps as needed.
Old 11-23-2010, 07:09 PM
sunroof/headliner
Thanks for info. Will see if I can fix in the next few play outtings with my baby. This 928 is one of the finist build machines on the road. LUV to drive it the way it was meant to be driven, A little hard, a little soft, ah listen to her talk.... Will post results/fix on my sunroof expedition. Have a good turkey day...
Old 11-24-2010, 11:50 AM
