Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 928 Technical Forum
Send a message via AIM to jojomanx Send a message via Yahoo to jojomanx
Porsche Crest wheels
How wide can we go with rear 928 wheels and tires on our 1980 928s?
What other Porsche wheels would fit our model 928?
Old 12-01-2010, 05:46 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
153bigblock's Avatar
I know 11's are no problem. Here is an 11 x 18 Moda Wheel on 78 (same hub) with at least an inch to spare (taken this weekend). Those early rears are tucked in.
Michael, So Cal
1985 Porsche 928, Black, 5 Speed
1985 Porsche 928, Weissgold Metallic, 5 Speed
1980 Porsche 928, Black on Black, 5 Speed
Old 12-01-2010, 07:43 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Pete R's Avatar
The fitment will be the same on all 928's, until the GTS and they can go a bit wider on the rear with the flared fender. You can run a 275 on the rear and 255 on the front no problem. The problem is it offset's at maximum fitment. No other model rims will really works well on the front. The boxster comes close. If you go below a 55mm offset on the front it will start to stick out of the body work like the pic above. It looks like 153 is using a 911 set up. My car is lowered so on bumps and turns there would be fender to tire contact. The pic is 245/35/19 and 275/30/19 The offset up front wheel is 19x 8.5 et 55 and think the rear is19x 10et45
Old 12-02-2010, 04:06 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
So what other Porsche wheels fit our 928?
Old 12-03-2010, 05:12 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Formerly from Bannlist
MPDano's Avatar
That width looks byotchen. What's with all the Painters Masking Tape? You building a Track Car?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior
Porsche928Forums.com (NOW Mobile Enabled!)
Old 12-03-2010, 06:14 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
The tape is left over from covering the quarter windows with plastic and yes, we are building a wide-body 928 track car a la....
Michael, So Cal
Old 12-03-2010, 07:30 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
MPDano's Avatar
Who is we?
Old 12-03-2010, 07:49 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
Pete R's Avatar
technically none, properly. All the Porsche wheels (5 x 130 bolt pattern) will bolt on but where the tires are in relation to the body will vary greatly. the 65mm offsett is pretty specific to the 928. You can go down to a 55et. on the front. That will incorperate some Boxter fitments. The whole range of wheels that fit the boxster may not fit the 928 but the ones 55et and up will. (all Dependant on rim width but in general) I'm talking on a stock body. The wide-body is completely different and I have no idea. Though it will look pretty cool.
Old 12-03-2010, 08:31 AM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
My friends Josef West and Chris Barrington - two 944 buddies.
Michael, So Cal
Old 12-03-2010, 12:11 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
MPDano's Avatar
Coolio. I was also wondering what ever happened to BB500 too. Anyways, sorry OP for going OT on your thread.
Old 12-03-2010, 12:27 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
pcar928fan's Avatar
The 5 spoke Carrera III wheel fits GREAT and has excellent 928 offsets. The CIII Lightweight well less so as it has a front offset of ET50...they still work and are my fav P-car wheels. The turbo twists seem to fit rather well...see them on a lot of 928's. As noted above the Boxster twist wheels fit fine. The stock front tire is way to small though and at 7" wide on the front you don't gain much where you need it. A wider front wheel that has a good offset for wider tires is the way to go on these cars really.
James
80 928 EURO S GT Club Racer, 81 928 Light Blue, 82 928 Comp Pkg Arrow Blue, 84 928 S Ruby Red, 85 928 EURO S Guards Red, 88 928 S4 Dark Blue, 92 928 EURO GTS Polar Silver, 94 928 GTS Grand Prix White
Old 12-03-2010, 12:31 PM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
Pete R's Avatar
8.5 x 55et is the farthest out you can go, as the wheel gets narrower the offset can decrease too. I agree, the Carrera wheels are pretty sharp. I bought wheels last year and it took me a month to figure out the correct fitment ratio.
Old 12-03-2010, 12:44 PM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
