I have the exact same issue with my CIS. It's probably not flooding, it just feels like it. It is most likely loosing pressure as everyone says. Most likely accumulator. (my theory) When the pressure drops the heat makes air bubbles in the fuel lines that purge out and make it stumble (like it's flooded) That's why no smoke or rich smell is noticed, it's not flooded. Also I noticed that the type of gas I use has an effect. I used to use Mobil and it always happened. I switched to Shell and it never happens any more. The only time I will have issue's is that first tank in the spring that is old and stabilized. Once I go through that tank it's perfect.
Well, I guess that I will start from the accumulator. Although in my case, I do have a strong smell of fuel after I start it with the gas pedal pressed to the floor :\
Troubleshooting Steps -
Hey Yoni, Even under the best of circumstances most experienced owners will readily confirm that it can be expensive to maintain a 928 - but to just start swapping out parts without taking steps to troubleshoot a problem can get real pricey very fast.
It is not that your planned attempt to change out the accumulator might solve your problem - it is just that this part can be easily tested. The accumulator is simply a sealed canister containing a spring on top of a flexible rubber bladder. As the bottom inlet is exposed to your operating fuel pressure the spring is compressed. It holds this position until the engine is shut off. With the fuel pump now stopped - the fuel pump check valve on the back end of the main fuel line and the injectors at the front end of the main fuel line are supposed to now seal the system. The accumulator spring (basically plumbed between the fuel pump and the injectors) now expands to hold a minimum of 14 Psi within the fuel lines - waiting for the next engine restart. Once the accumulator is removed - it is simple to test. Apply about 25 psi to the bottom inlet port using an air nozzle. This will compress the spring. No air should pass out of the top connection. When the air nozzle is removed, the spring will extend and push the air out. You should not have to step on the accelerator to restart a cold or warm engine. Good Luck, Michael :) |
Jk's right. Test as much as you can first. Since you do have the gas smell I assume you are getting plenty of gas , maybe too much. A failed accumulator would most likely not create that. I would look towards a leaky cold start valve and/or the components that control it.
hmm.. seems like my car problem.. Will read it later..
Well, found the problem...
amazingly it was a battery problem!!! it seems that it has some sort of internal malfunction. So thats why from time to time it didnt have enough power! it did have enough power to turn the starter but not enough for all other electrical systems... I just replaced the battery and the car starts immediately at any time :) I am sooo happy! |
Excellent!
Sorry to lead you all over the place. Michael had the voltage thing pegged, though, didn't he? Congrats! |
indeed! :)
thanks! |
More-Better Capacity
Naturally, it is important to only install a fuel pump that is capable of producing the correct operating pressure and flow rate - this is especially true for a high performance vehicle. During the troubleshooting phase of this post, I had only mentioned to Yoni that he may have to update his fuel pump if he had the earlier design (with the internal snout check valve) and the check valve was defective. Some 928 owners install a newer style pump not only for the replaceable check valve but for the ability to install a larger pump with more-better operating capacity.
Michael :) |
| All times are GMT -8. The time now is 12:52 AM. |
